Old 11-14-2006
seeker
feetup is on a distinguished road
Softening or removing silicon sealant
There are two decklights on a boat I recently bought set flush into the deck and held with sealant. The previous owner has attempted to seal them with what looks like an entire tube of silicon. The lights themselves appear to be of 3/8 to 1/2 inch plexiglass or lexan with about 1/8 inch of space around the perimeter for sealant and about a 1/2 inch lip under to support them. The question I have is this...How do I remove the silicon, and loosen the plexiglass so that I may re-seal properly, without destroying all and sunder?
Is there anything that will soften silicon? Could I use slow, increasing pressure from underneath till they pop? Heat?
Gratefull for any help.
Feetup
Old 11-14-2006
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
razor blade & elbow grease.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 11-14-2006
And lots of the latter..
BTW, using brute force is generally a really bad idea.
Old 11-14-2006
niorn is on a distinguished road
Hi,
You should try a product called Debond or 3M Silicone softener. Debond works the best.
Old 11-15-2006
seeker
To niorn
Thanks niorn
I suspected there would be a product to soften silicon, do you know if it is safe on fiberglass os lexan?
The reason I am looking for an alternative to a razor blade is that the interface between plexiglass and fiberglass forms a right angle that would be very difficult to cut into.
Feetup
Old 11-15-2006
redcorvette1995 is on a distinguished road
Hi!
Debond will attack lexan.
I don't have any experience with the silicon softener.
I would try and test it first.
Todd
Old 11-15-2006
hellosailor's Avatar
Feetup, I would expect most of the solvents could hurt (eventual cracking and crazing) your deadlights, whether they are polycarbonate or (more likely) plain acrylic. If you can drill or pick or chew one small hole all the way past the edge, you can pass a piano wire or mono fishing line ("Spidersilk" or other aramid/kevlar material) through the hole, and working with two people, saw it back and forth around the deadlight to cut the sealant.
Depending on what it was bonded with and how well it was bonded, simply pulling or pressing just may not do anything. Using a heat gun and really heating it up as much as you dare, might help release it.
But you may just need to replace the deadlights, or find that's the easiest thign to do. If they are just 1/2" sheet plastic, any plastics shop should be able to made replacements for you at a reasonable cost.
Old 11-15-2006
The product manufacturer should be able to tell you if it will attack different materials.
Old 11-16-2006
Doug_53 is on a distinguished road
Try WD 40 and a plastic scraper
Jack Tar
Old 11-16-2006
WD40 is effectively kerosene, it will harm both lexan and plexi unless immediately and thoroughly washed off. Makers of both say simply "never" to get petrochemicals on them. (Long term crazing downline.)
