I just bought a Alden 44 and I have a problem with the centerboard mechanism.
Has anybody an idea how it works and or drawings details and the access from the keel?
The hydraulic system is working fine but the centerboard doesn't move :eek
Hi,
I sail Puffin, Alden 44 hull #4 on the San Francisco Bay
Last year I had the boat hauled and wanted to get the centerboard cleaned. I pumped the board down while in the travel lift and it didn't budge. It turned out that the board had disintegrated around the shaft so the shaft was rotating but it was just spinning in the board.
The shaft exits the bilge through a stuffing box like thing and I think the port end is supported with a bearing or bushing embedded in the keel.
There is a notch in the starboard side of the keel and the bilge extends down to contain the hydraulics and actuator arm.
To get the shaft out, the yard cut a 12 inch hole in the bilge centered about the shaft. They then removed the actuator arm and pushed the shaft out through the port side. They rebuilt the centerboard, remounted it and glassed back over the hole.
It was not a cheap operation, but I was able to claim some of it on insurance.
Hi,
I realize it’s been several years, but am reaching out because we’re looking at an Alden 44 that has had it’s centerboard removed and are trying to figure out what would be involved to replace it.
May I ask what the cost was to reinstall your centerboard, and was the hydraulic system still intact, or was that replaced as well?
Thank you so much for any information you can provide!
Related Threads
1.7M posts
173.8K members
Since 1990
