I have a 1985 Honda 5 HP, 4 Stroke long shaft. The cooling action is normal only while the outboard is in NEUTRAL, BUT when I put the engine in gear (either forward or reverse) the cooling water flow would be greatly reduced to a "SPITTING"! This is my second engine and I'm having trouble getting on the water where I need to be. Does anyone have any ideas on why this outboard cooling water will not flow normally while under load? Thank you very much.
Probable cause:
The elasticity of the rubber vanes of the impeller has decreased (the vanes have taken a 'set' into a deformed position), so that at the higher rpm the vanes are no longer in close contact with the impeller body and are 'floating' away from the impeller body surface due to hydrodynamic lifting of the vanes.
Rx: replace the impeller as a first attempt of correction.
First I'm going to have a Margarita!!!! then the impeller Thank you all for your guesses/ideas.
Related Threads
1.7M posts
173.8K members
Since 1990
