11-24-2006
Transmission coupling bolts
I discovered a problem in my bolts the hard way when leaving my slip. The transmission went into forward and reverse properly with no effect. After the foredeck fire drill to set the anchor, I found that all four bolts (1989 ODay 40, Westerbeke 46) had spun out. I managed to salvage three sets from the bilge, which was enogh to get back to the slip. Next day, an enitire new set of bolts and washers were installed, and I check them regularly, although no sign of loosening has occurred-yet. Previous boat was a saildrive, so very few similarities. There was no compression piece between the flanges, but I will check the manual (again) now that I recognize the possibility that one should be there.
Bill Coxe, O40, New London, CT
