New England Salsa Braid Splice - SailNet Community
post #1 of 5 Old 06-22-2016 Thread Starter
overbored's Avatar
Have some new 5/16" salsa single braid and have come to the conclusion that it can not be spliced with a locked Brummel splice or any splice. or if it can not worth the trouble. anyone done it?
"GOLD RUSH" PRINDLE 16
overbored is online now
post #2 of 5 Old 06-22-2016
Re: New England Salsa Braid Splice
Salsa is generally spliced by a tapered bury with a lock stitch not a brummel. The tapered bury is pretty easy, the weave is a little tight compared to amsteel, but it's still pretty quick to do.
Greg
Stumble is offline
post #3 of 5 Old 06-23-2016
Old enough to know better
Did you get extra spicy or mild, I have heard the spicy is really hard to splice. (Sorry could not help it)
I thought single braid hightech line got Brummel splices, but I see it listed to use 12-strand eye splice.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #4 of 5 Old 06-23-2016
The Brummell has consistently been shown to be weaker than a lock stitched eye splice, but some find it easier to make. The strength difference is marginal, about 5% loss I think.
Greg
Stumble is offline
post #5 of 5 Old 06-23-2016
I pondered this attachment problem when securing the ends of my new T-900 halyards to their shackles. Finally decided that if(!) the experts were right about a potential reduction of as much as 50% of the line strength, then my 5/16" halyard, rated at 7000# would never lack for strength enough to hold up any of my sails.
And so I decided that further worrying might get too near the mental black hole of "overthinking" the whole question.
That was about ten years ago or more.
YMMV.
These modern lines are really really (!) strong.
Further, when you need to remove the halyard for washing, it's easy to stitch a tag line to one end to feed through the spar.
Also, by using a (halyard) knot rather than a splice you would later have to cut off, you can easily end-for-end the line after cleaning it.
Loren
olson34 is offline
Eye splice in double braid flyingwelshman General Discussion (sailing related) 32 04-21-2013 07:19 AM
Eye splice in double braid finally davidpm Gear & Maintenance 15 01-07-2011 10:11 AM
Question About Double-Braid Eye Splice Procedure SEMIJim Seamanship & Navigation 13 12-08-2008 08:38 AM
Anybody ever splice Marlow Braid Quickstep192 Gear & Maintenance 5 05-24-2008 08:24 PM
double braid eye splice dorourke Gear & Maintenance 16 03-19-2008 10:32 PM
