mast compression on beneteau 381 - Page 2 - SailNet Community
post #11 of 12 Old 11-25-2006
"The "over-tightening rigging" sounds like a red herring " Not necessarily. I've seen the head doors jam in a number of boats because of over-enthusiastic rig tightening. Among other things.
If there's a solid filler under the mast (as there should be) and there's a compression post/beam/system under the deck (again, as there should be)...You'd have to do a real gorilla job to compress a good marine grade filler under the mast. But I think we've all met marine gorillas, I just can't remember the proper Latin name for the species.
"Yeah just stick a plate under it to regain the thickness and slack off the rigging" could actually be simply good advice, once upon a time that's how things were "made do" done. OF course, as a card-carrying cynic I'd be reluctant to do that without opening up the deck and actually SEEING what had happened inside it. Or getting something else (ultrasound?) to see inside it without peeling it open.
It sounds like this is worth a longer call to Beneteau, to ask them for more information on the larger picture.
hellosailor is offline
post #12 of 12 Old 11-25-2006
can't re member
I think Hello has you on the right track. For you to purchase this boat you should first determine what has compressed and why. Then you will be able to judge whether your shim is a cure or a cough medecine. It would seem to me that Beneteau, by suggesting the shim, feels that it has compressed as much as it can. Now they want you to bow the thinner, compressed section of deck upwards. Could it be that the real solution would be to rebuild that portion of deck from something less compressible? (Thus fixing any potential water intrusion simultaneously.)
Did the compression post actually "sink in" to it's step? If so then shim. If not, fix the real problem.
Oh yeah, ignore all the Beneteau haters. It's not just your boat they hate, it's most boats!
yotphix is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
