11-25-2006
"as long as you keep the black negative it is fine. "
Not any more. Black is used as the color for the neutral ("return") in AC mains wiring, but on shipboard DC systems the new standards have been YELLOW for negative and red for positive, for years now. Since there's a real possibility of getting those two very different black wires crossed and doing major harm...No more black wires on boats.
Duke, it might be simpler and cheaper to buy a 50' or 100' spool of the 14x5 cable, and then simply slit back the outer jacket for a foot or so where you need to pull out the spreader wires. If you can't pull those two wires back all the way in the jacket, just cut them at that point and leave the rest in the jacket. (Yeah, heresy if you're a racer and concerned about weight aloft, I know. ) And yes, you can "t" into the ground wire that's coming down from the masthead in that same place, no reason you'd have to run separate grounds, just make neat splices and seals.
AFAIK ground should be green these days, same in AC and DC systems.
