Old 11-26-2006
Living the Dream
dnseal is on a distinguished road
Holding conduit in place while fastening
Whats the best way to hold the pvc conduit in place for drilling and riviting? I was told to use irrigation pipe by local rigging company and I already have a large two handed rivit gun for the SS rivits.
I also have a concens with the SS rivits an the irrigation pipe; can the rivits crack the thin wall of this irrigation pipe when compressing? Would hate to hear an extra crack while midway through the project.
gil
Old 11-26-2006
A simple way to hold the conduit in place is described in one of Don Casey's books and involves using stiff wire, like a coat hanger, bent into a hook shape to pull the conduit against the mast wall so you can drill and pop rivet it in place. Don't forget to coat the pop rivets with an anti-corrosion compound like Tef-Gel or Lanocote.
Basically, as I recall it, you drill a few holes in a line parallel to where you want the conduit and stick the coat hanger "hooks" through them and pull the hooks over the PVC pipe and pull them tight, bending the coat hanger to hold them in place at each point. When you're done, unbend the coat hangers and withdraw the hooks, and fill the holes with epoxy.
Old 11-26-2006
hellosailor's Avatar
I came across an old British mention about running wires up the mast, which I'd never heard of before. They simply ran the wires "free", and then inserted a rolled-up sheet of thin polythene plastic in the mast. The polythene of course tries to unroll so it flattens against the inside of the mast, which prevents the wires from slapping around AND neatly forms an anti-chafe shield between them and any lines.
Since there are no rivets, no ties, no glues, it seems like an elegantly simple way to do things. Assuming you can find a 50+ foot long roll of thin sheet polythene to stick up the mast.
Old 11-27-2006
Gramp34 is on a distinguished road
Here's a couple even easier ideas:
1) Run your wires inside 1/2" pipe insulation, and pull it into the mast.
2) Get a bag of 8-12" ty-wraps (aka zip-ties, cable ties, etc.), put them on the wires about every foot, with the long tails pointing in different directions, and pull it up the mast.
I did option #2 last year. Quick, easy and no noise from either the wiring or the two internal halyards afterwards.
Cheers,
Tim
Old 11-27-2006
Living the Dream
Option 2 sound interesting and it keeps the mast free of additional/numerous rivits, but is this really a viable method? Has anybody else used this method?
Gil
Old 11-27-2006
I like the pipe insulation idea - it will muffle any noise; the spiky ty-raps ought to hold the whole assembly somewhere within the mast.
One downside I can see is if you ever broke a halyard, running a new one through the forest of plastic could be a nightmare.
Old 11-27-2006
My first choice would be to use an electrician's fish tape, e.g., http://www.harborfreight.com/cpi/cta...emnumber=38156. They're stiff steel wire that wants to stay straight so you can shove them into conduit runs and pull your wire back. Only about $10 if you don't have one or can't borrow one. A fish tape would have no trouble getting through the ty-wraps.
Tim
Holding Tank Questions John_colpitts Gear & Maintenance 14 08-31-2006 06:42 PM
Holding tanks foxglove General Discussion (sailing related) 17 08-12-2006 04:03 PM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 09:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 09:34 AM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
