Onboard dehumidifier - SailNet Community
post #1 of 2 Old 07-08-2016 Thread Starter
Came up in another thread.
My AC unit has three settings: Heat, Cool and Dehumidify.
The raw water pump does not circulate water, when in dehumidify mode. I only set it that way, when leaving for more than a day, so for all I know, it cycles on/off. However, I've noticed it's not pumping water, as I'm leaving and I can hear the air handler running.
I would have thought the dehumifier would also require heat exchange. Maybe they're defective.
Can anyone educate me?
Jeanneau 54DS
Minnewaska is offline
post #2 of 2 Old 07-09-2016
Re: Onboard dehumidifier
In the dehumidifier mode the fan on the air side of the system would run continuously. The raw water pump/compressor should only cycle on whenever the humidity rises above the setpoint. In theory that's how it should work so that MAY explain why the raw water pump isn't energized. If you've had the AC on prior to leaving the boat the air is already dehumidified.
I remember on one of my powerboats the raw water pump ran continuously whether there was a load on the compressor or not so maybe it is defective. Time to break out the manual
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
Low Power Dehumidifier aa3jy Gear & Maintenance 6 05-03-2016 06:36 PM
Can you run a dehumidifier too much? Rasputin Gear & Maintenance 11 03-03-2015 04:27 PM
FYI--Dehumidifier Recall svHyLyte Electrical Systems 0 11-26-2013 11:12 AM
Dehumidifier in wet/rain PNW? SV Glossa Living Aboard 45 01-18-2013 04:12 AM
Dehumidifier help please... RNC725 Gear & Maintenance 4 02-28-2012 03:11 AM
