New (to me) tool - SailNet Community
 1Likes
  • 1 Post By davidpm
post #1 of 4 Old 07-25-2016 Thread Starter
davidpm's Avatar
New (to me) tool
I was teaching a class and on the way back the engine refused to run.
the problem ended up being the fuel pump.
We called the mechanic and he was able to confirm my diagnosis in about one minute.
He used this gadget.
http://www.powerprobe.com/IV/
It is a pretty common technique to have a 40' wire on board with alligator clips on boat ends so you can go directly from the battery to the device you want to test.
This gadget does the same thing but with a built-in voltmeter.
Not necessary but pretty slick.
bristol299bob likes this.
davidpm is offline
post #2 of 4 Old 07-26-2016
Learning the HARD way...
eherlihy's Avatar
Re: New (to me) tool
and this is better than a good DVM how?
eherlihy is online now
post #3 of 4 Old 07-26-2016
Barquito
Barquito's Avatar
This tool is better than a multi-meter because it is slick! Maybe a little easier to handle because it has a dedicated probe on one end. I am constantly trying to find someplace to balance my multi-meter so I can put a probe in each hand. Otherwise, I don't see any difference.
Valiant 32
Barquito is offline
post #4 of 4 Old 07-26-2016
travlin-easy's Avatar
The big advantage is that you have the readout in your hand while testing, which beats the heck out of finding a place for the DVM to sit while you attempt to insert the test lead, keep it in place, then turn around to see the DVM. Neat idea.
Gary
travlin-easy is offline
Most Useful Sailing Tool CatMan22 General Discussion (sailing related) 38 03-18-2014 01:15 PM
I need a tool.... sailak General Discussion (sailing related) 6 08-08-2013 02:29 AM
Tool needed poopdeckpappy Gear & Maintenance 13 03-10-2008 01:21 AM
Re: FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Run NewsReader Mass Bay Sailors 0 03-04-2007 11:15 AM
FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Runs on NewsReader Mass Bay Sailors 0 03-03-2007 04:15 PM
