freshwater systems - SailNet Community
post #1 of 4 Old 11-15-2001 Thread Starter
freshwater systems
Welcome all recommendations re: freshwater pumps, 3-4 outlets, ie. Whale vs. Shurflo vs.Flowjet. Concerned about noise, dependability, need for accumulator tank.
Thanks, Joe
joseph53p is offline
post #2 of 4 Old 11-15-2001
freshwater systems
I have had Jabsco(Par) pressure water pumps on all of my boats with excellent results. Currently, I am running a galley sink, two head sinks, two showers and a cockpit washdown all with the same pump. I have used this pump for six years and have rebuilt it once and also had a pressure switch go. I also use a 1 1/2 gal. pressurized expansion tank in order to keep the recycling to a minimum. I also have an in line filter
between the tank feed and pump. The pump is a Jabsco model 36900-1000 which is available in the discount catalogs for about $320.00. I also keep an extra pressure switch and service kit on board.
SHIMSHON is offline
post #3 of 4 Old 11-15-2001
freshwater systems
I have had Jabsco(Par) pressure water pumps on all of my boats with excellent results. Currently, I am running a galley sink, two head sinks, two showers and a cockpit washdown all with the same pump. I have used this pump for six years and have rebuilt it once and also had a pressure switch go. I also use a 1 1/2 gal. pressurized expansion tank in order to keep the recycling to a minimum. I also have an in line filtereen the tank feed and pump. The pump is a Jabsco model 36900-1000 which is available in the discount catalogs for about $320.00. I also keep an extra pressure switch and service kit on board.
SHIMSHON is offline
post #4 of 4 Old 11-15-2001
Senior Nappy Headed Ho
freshwater systems
I don''t have first hand experience with any of the pumps you mentioned however I would not let that stand in the way of commenting on the subject matter. I have a Jabsco fw pump in my boat that has served my needs quite well for the past 8 years. Regardless of your decision on which pump to buy, one should have either a “pump integrated” accumulator or one in-line to prevent the pump from cycling on each time a small amount of water is used. Unfortunately, many boats come from the factory without accumulators. Based on my personal experience on other boats, it is very annoying to hear the pump cycling on and off each time a small amount of water is used. I replaced the standard air charged accumulator on my boat with one that uses a latex bladder. This accumulator never looses its charge. That’s my story and I''m sticking to it like 3M5200!
Denr is offline
Mainsail slide systems psotis Gear & Maintenance 11 09-10-2006 10:10 PM
Freshwater vs Saltwater boat; ASA courses NJW3 Boat Review and Purchase Forum 6 09-06-2003 06:42 AM
Mainsail Furling/Reefing Systems camaraderie Gear & Maintenance 10 06-27-2003 02:52 PM
Jib Furling Systems - Results robrichtx Gear & Maintenance 0 12-15-2001 10:21 AM
Kato Marine Davit Systems waddison Gear & Maintenance 0 11-27-2000 10:14 AM
