Low buck bow thruster?? - Page 5 - SailNet Community
 23Likes
post #41 of 54 Old 11-17-2013
Re: Low buck bow thruster??
I find myself ignoring sailnet more and more but I couldn't resist commenting on the content of this tread. As i see the issue, the best concept for handy manoeuvring would be two of those easily maintained units recommended by Kellysails (long tails from Thailand) Mounted bow and stern and tethered together, connected with steering ropes to a centrally mounted vertical shafted steering wheel out of a bus .This would facilitate docking and negate any need for development of boat handling skills . Which is probably good because as used in Thailand ,there is no reverse. This small oversight requires the addition of Hundystad pitchable props controlled by a second bus steering wheel for finessing the docking experience The rig as i describe it is so elegant there would be no need of hiding it in a locker after use.and may well be emulated by fellow boaters. Good ideas often are.
Andrew65 likes this.
Capt Len is online now
post #42 of 54 Old 11-18-2013
Originally Posted by Pamlicotraveler View Post
I use a leaf blower on my boat. The engine is small, although a little loud, especially when submerging the blowing end in water to make the turns. The reason I use it instead of the trolling motor is that I have found it more useful in dead air. I can just blow in the sails and find that it moves the boat along rather nicely. It also works for cleanup in the cabin.
Can you use an electric blower off the inverter, or do you have to have gas? I don't like gas onboard because it's dangerous.
xymotic is offline
post #43 of 54 Old 11-18-2013
At my Helms 27
The easiest and simplest solution is a spring line attach to the stern. Hauling in line causes the bow to rotate in the opposite direction.
drsutton is offline
post #44 of 54 Old 11-18-2013
Owned by Velcro
Ferretchaser's Avatar
I like the bow thruster I put in my boat. I negated the need to the big cables to run it by putting a 130 Ah battery close to it and just run cables for charging it there. I got it cheap from a boat yard in the UK when I built my boat and like it a lot.
It has 160 + lbs of thrust and helps with the handling in tight spaces as I do not have crew to hand a paddle to.
ATB
Michael
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #45 of 54 Old 11-18-2013
Originally Posted by luhtag View Post
........In fact I'm sure all of you could dock an 80 footer under sail in a hurricane from the v-berth using nothing but your telekinetic powers while you make love to one of your super model concubines.
From this moment forward, I won't feel like I've earned my stripes until I pull this off.
A real keeper!
Jeanneau 54DS
Minnewaska is offline
post #46 of 54 Old 12-22-2013
bljones's Avatar
Dfok and jimgo like this.
It's 5 o'clock somewhere:
bljones is offline
The Following User Says Thank You to bljones For This Useful Post:
Dfok (12-23-2013)
post #47 of 54 Old 12-23-2013
I'm speechless. Even a good stinkpotter jab would seem inadequate.
Jeanneau 54DS
post #48 of 54 Old 12-23-2013
Andrew65's Avatar
Originally Posted by wildcard View Post
I was thnking so I decided to ask here. Has anyone used a remote control electric trolling motor as a bow thruster? Im thinking it would be a great thing for close quarters maneuvering. Of course it would have to be kept coverd at the dock to avoid thousands of stupid comments.
...so you have decided to come here to get Your thousand?
Ok, here goes one for ya. Tie Your kid off the bow With a pair of flippers on and then toss candy to the side you want him or her to swim to pull Your bow around.
Andrew65 is offline
post #49 of 54 Old 12-23-2013
JoeLena's Avatar
How long is the extension cord on that thang?
'72 Catalina 27 Tall Rig #519
JoeLena is offline
post #50 of 54 Old 12-09-2014
__floater__'s Avatar
BOOM!
Originally Posted by bljones View Post
I think luhtag simply stated what many of us thought when we read the first few pages of replies to the OP's question.
Frankly I was surprised how harsh some of the replies were. Not at all what I expected from a place which I thought existed to help sailors.
Turns out all the smart-a**es have egg on their faces. Perfect.
SV Whisper
1981 Aloha 8.2
Hull #50
__floater__ is offline
Bow thruster Artwerke Gear & Maintenance 2 06-15-2006 03:58 PM
bow thruster installation Myblueheaven Gear & Maintenance 1 09-10-2004 02:26 AM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 07:00 PM
