Old 12-03-2006
wildcard is an unknown quantity at this point
To bond or not to bond, that is the question!
I searched here but did not find what i was looking for. being new to the plastic boat world, I find myself at somewhat of a loss here. Quick run down. Glass boat, bronze thru hulls, currently bonded but the bonding strap and connections are looking kind sketchy. The problem? My thru hulls are at 290-300 Mv and should be at 500. I was going to try to loosen and clean all the fittings but that looks like a nightmare due to space and location. So here are my questions: What could be causing the low voltage? What can I do about it? and should I rebond or unbond the fittings and why?
Many thinks in advance!
Old 12-04-2006
I think this depends a lot on what you are bonding for. There are two reasons to bond... one is lightning protection, the other is to prevent galvanic corrosion. Which are you trying to do?
Old 12-04-2006
corrosion primarly
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
Quick displacement question... kclaybrook General Discussion (sailing related) 19 07-13-2006 08:30 PM
Cruising home/base/marina ICW question thorJ30 General Discussion (sailing related) 3 05-30-2005 05:53 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
Glassing Question pirateofcapeann Gear & Maintenance 6 05-29-2003 02:58 AM
