Blogs
User Name
Old 12-05-2006
tomgee tomgee is offline
tomgee is on a distinguished road
Shrink Wrap or Custom Cover?
Hi,
This is my first season as a sailboat owner (1980 Sabre 28). I'd appreciate any comments on going with shrink wrap versus getting a custom cover made. From cursory research it appears a custom cover would be about 5 times more expensive than shrink wrap.
Thanks!
Old 12-05-2006
gunkholemarine's Avatar
gunkholemarine gunkholemarine is offline
gunkholemarine is on a distinguished road
Cover choice
As a dealer, I always use shrink wrap because I never expect to keep the boat very long. Also, I don't have to do it myself.
For boats I own personally, I choose a custom cover, especially if I plan on keeping the boat for long enough to recover the cost of the cover.
Kevin
gunkholemarine.com
Old 12-05-2006
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
If you're going to keep the boat more than five years, get the cover...since it will probably last more than five years, and will pay for itself in that time.
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
Old 12-05-2006
paulk paulk is offline
paulk is on a distinguished road
Is the cost of shrink-wrapping your boat each year going to go up or down? What happens when they add a $200 recycling fee, on top of that? The canvas covers we use for our boat have lasted ten years. Pay once, do it right and be done with it!
Old 12-05-2006
mike dryver mike dryver is offline
mike dryver is on a distinguished road
the first yr we had our boat it was shrink wrapped by the prev. owner. even with vents the boat was soaked all the time. every week i had to open the door for a day at least to alev. the prob. last winter i put on h/d silver poly tarps overlapped at the mast by 6'. had no prob what so ever with condensation at all. the reason was because i did not seal the overlap, and air could get under the tarp along the hull and pulpit. the only water that came in was around the mast and the stays. there really is no good way of sealing those areas unless you duck tape the hell out of those areas and then you have clean off the residue in the spring.
Old 12-05-2006
CapnHand's Avatar
CapnHand CapnHand is offline
humble pie rat
CapnHand is on a distinguished road
Don't you pull the stick when you haul out?
Old 12-06-2006
sailaway21 sailaway21 is offline
Owner, Green Bay Packers
sailaway21 is just really nicesailaway21 is just really nicesailaway21 is just really nicesailaway21 is just really nice
Check this site out for a better/cheaper solution. With proper rigging you can even work on your boat in the winter.
www.bosunsupplies.com/Cover.cfm
Old 12-06-2006
Goodnewsboy Goodnewsboy is offline
Goodnewsboy is on a distinguished road
I like the custom cover. Mine is being made for about 3x the price of one shrinkwrapping. It is strong enough to shed a heavy snow load, ventilates the boat, gives me access during winter, and has a projected life of 10 years.
Tarps can be OK if you spend enough time building a secure frame, and if you can fasten them securely enough. I just took the easier route.
vB code is On
adding a wrap bkw Racing 9 01-26-2007 02:57 PM
shrink wrap VS. no cover ddilman Gear & Maintenance 6 11-15-2006 11:28 PM
Fairclough custom cover for Freedom 35 available in RI faithab General Discussion (sailing related) 0 03-01-2006 11:27 PM
Mainsail cover davejean General Discussion (sailing related) 2 11-04-2003 08:19 AM
UV Sock Cover Don Casey Gear and Maintenance Articles 0 01-28-2001 08:00 PM
Page generated in 0.5248 seconds (67.49% PHP - 32.51% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
