Old 12-05-2006
Stylemaster
freeheel999 is on a distinguished road
Conversion from In-Mast furling to Lazy-Jacks system possible?
Is this possible?
I'm looking at converting a conventional in-mast furling system on a 50ft Beneteau to a lazy-jacks system/battened main.
Does anyone have any practical experience of doing this, or know of anyone who has done a conversion?
I believe that special extrusions are available which insert into the existing mast slot and (after being fixed in position) provide a new external track which will allow for the conversion to the lazy-jack sliding cars...is this possible to do?
Old 12-05-2006
It may be possible but there's a lot of hardware involved with the in-mast furling that you needn't pack around afterwards - you'd be better off with a mast designed for conventional hoisting.
Converting the existing mast will mean extra unneccessary weight aloft.
Maybe you can find someone without in-mast furling that wants it and swap rigs!
Old 12-05-2006
I agree, if you want lazy jacks and slab reefing...get a different mast... the reduced weight aloft will mean the boat will sail better.
Old 12-05-2006
And if you sell your actual mast and sail, it actually helps paying for the new mast, too.
A lot of people would like to have those on their boats. Post it for sale, who knows??
Old 12-06-2006
Stylemaster
Cheers for the replies...and I hear you on the concept of replacing the mast - however this isn't necessarily a cheap or convenient option for me right now.
The question remains...does anyone know of a system or extrusion by any of the major suppliers of hardware that would adapt the existing slot and convert to using a new 'car' system?
ie Harken have a system called 'Battcar' which involves using specially shapped extrusion 'slugs' in the existing mast slot (admittedly of a conventional bolt-rope slot) which are tightened and held fast (glued also) when the external track is attached. External 'cars' are attached to the track and voila...you have a new system! Wondering if this system would work?
Old 12-06-2006
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
You could look into StrongTrack. It's an extrusion that fits your mast slot and employs stainless steel slides. Standing at the mast, I can raise my main by hand, and from the cockpit, only need to winch the last few inches. Ran me $860 for 34'. The advantage to me, over "battcar" systems is there are no bearings involved. It could be a short term fix, but as others have said, you really should swap out the mast.
Regards,
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 12-06-2006
captlar's Avatar
can't re Member
captlar is on a distinguished road
I'm no help, freeheal999, but curious as to why the change. No interest in finding a higher quality in-mast furling system or just hate the whole deal ?
For my 10 cents, I've had both LazyJacks and Dutchman, and had the new main built with new Dutchman. Slick as a smelt.
Good luck !
Larry
Old 12-06-2006
PBzeer-
The strongtrack system won't address the extra mass caused by having the unused in-mast furling system on the boat.
Old 12-06-2006
PBzeer's Avatar
Wandering Aimlessly
I know SD, that was the purpose of the last sentance.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 12-07-2006
Stylemaster
Good luck !
Larry
No...bought the boat with in-mast and have always sailed boats with battened mains. For me it's totally a performance thing despite the extra hassle. I sailed a similar boat recently with a new lazy-jack system and fully-battened main and it performed so much better....
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 07:00 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
