Mainsheet rubbing vang... - Page 2 - SailNet Community
post #11 of 17 Old 12-09-2006
T
SD says its a bimini, not dodger!!
Giulietta is offline
post #12 of 17 Old 12-09-2006
Thanks Courtney.
But what does the guy that ownes the boat say?
T34C is offline
post #13 of 17 Old 12-09-2006
Giulietta-
The problems I see with the mainsheet running directly from the forward boom bail block to the foot block are:
1) the load on the mastbase block increases dramatically;
2) the mainsheet is now an obstacle that will sweep the area under the boom;
3) the mainsheet may cause problems with the hatch that is present,
T34C-
If the boat requires the use of a mainsheet winch, you can probably increase the purchase of the mainsheet by changing the blocks on the boom and traveler, and possibly even eliminate the need for a mainsheet winch.
However, if the increased leverage won't be sufficient, then you will have to run the mainsheet forward to the mastbase block, probably by moving the existing to just aft of the boom vang attachment, so that the main sheet parallels the boom vang but leads fair to the mastbase block.
This should avoid most of the problems associated with just running it from the existing mid-boom sheave to the mastbase block, but the loading on the mast base block will be significantly higher.
My reasoning that the tubing you see is for a bimini is that it is angled down and aft in the photo...which means it is attached somewhere in the cockpit, which is very unlikely for a dodger, and very typical for a bimini. The bimini frame on my boat, when lowered forward, ends up in almost the exact same position relative to the sliding hatch and companionway.
sailingdog is offline
post #14 of 17 Old 12-09-2006
Thanks Courtney.
SD-
Agreed. It looks from the picture that there is an unused bail just aft of the vang that could have another block in-line then lead to the mast base block without creating any more significant obstruction that the vang currently does. The blocks in the pic. look to be Garhauer 40 or 50 series blocks with a safe working load of 2,800 and 3,000 lbs. respectivly. They should be up to the job.
T34C is offline
post #15 of 17 Old 12-09-2006
Senior Moment
SailorMitch's Avatar
I agree with T34C that a block on that unused bail just aft of the vang will allow the mainsheet to be routed to the turning block at the base of the mast without creating much more of an obstruction than the vang already represents. That is exactly what i have done on my P-33-2 and it works great. (I have a soft vang for now but probably will buy a Garhauer rigid vang this winter. Denr is ragging on me too hard about that soft vang!)
Alternatively, SD's suggestion of changing out the mainsheet treatment at the traveler so that it is all contained there has merit as well. I did that on my previous boat with great success. But that depends on whether there's a dodger in the way of getting to the car on the traveler. The advantage of this option is that it cuts down on friction quite a bit, and you also can increase the leverage if needed to control the main in almost any conditions.
Either option should work.
Yes, nice Garhauer blocks -- I think the same ones I now have on my P-33-2.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #16 of 17 Old 12-10-2006
ASA and PSIA Instructor
Mitchell,
If the friction and chafing are not significant problems, I'd leave the system alone.
If you eliminate the block at the gooseneck, you end up with the same sheet geometry as has worked fine on my CS 36T. You can continue to use the mainheet winch on your cabintop, and no changes will interferr with your dodger (the picture shows a dodger frame - arn't those Garhauers sweet...) As you know you can't switch to a cam on the mainsheet block as you can't reach that block when the dodger is installed and up, plus you'd loose the sheet winch...With this new geometry the sheet will tend to hang up on the hatch if it is opened more than a few inches...
sailingfool is online now
post #17 of 17 Old 12-10-2006 Thread Starter
S/V Perwinkle
Thanks for all the help folks.
I think i'll try moving the sheet to a block just aft of the vang, then run down parallel to the vang and on ...
Will the load on the mast base block be too high?
Much thanks for all the input.
P.S., The pic is actually not my boat. Mine is a Pearson 39 MKII with a very similar setup. I do have a dodger.
lmitchell is offline
rigid vang for small sloop or... Any excuse to upgrade. jbarros Gear & Maintenance 2 10-16-2003 03:01 PM
Mainsail Controls for Performance, Part Two Dan Dickison Gear and Maintenance Articles 0 02-27-2002 08:00 PM
Mainsail Controls for Performance, Part Two Dan Dickison Racing Articles 0 02-27-2002 08:00 PM
New and Improved Laser Controls Dan Neri Racing Articles 0 11-28-2001 08:00 PM
Mainsheet Systems Dan Dickison Gear and Maintenance Articles 0 10-22-2001 09:00 PM
