Old 12-15-2006
trodzen is on a distinguished road
Send a message via AIM to trodzen Send a message via MSN to trodzen Send a message via Yahoo to trodzen Send a message via Skype™ to trodzen
Backstay Insulator for SSB
I installed a SSB a while back. I did it when I was outside of the USA so I did a semi-temporary wire up the backstay. Now it's time to remove that and install a proper antenna using the backstay and insulators.
My question is with the insulators. I found sailnet offers the Sta-Lok version
http://shop.sailnet.com/product_info...ducts_id/32703
http://www.stalok.com/online_shop_it...44&sec_id=1575
And Defender offers a version from Hyan called a HI-Mod Insulator
http://www.hayn.com/marine/rigging/himod.html
Anyone, please comment on the quality of either or experiences installing an insulator with the stick already up.
Old 12-15-2006
btrayfors will become famous soon enough btrayfors will become famous soon enough
Why Break Up a Perfectly Good Backstay?
Why break up a perfectly good backstay with 4 more possible points of failure?
How about a semi-permanent alternate backstay, made of s/s lifeline, hauled up with a spare halyard, and affixed at the lower end to the pushpit on one side of the boat?
I've used one on my 42' sloop for 17 years now; no problems. Works every bit as well as an insulated backstay, and without the expense or compromising the integrity of your backstay.
Bill
WA6CCA
S/V Born Free
Old 12-15-2006
my semi-permanent solution was similiar. I attached a covered wire to the backstay with zip-ties. I used it to talk with Herb in Canada while off the coast of D.R. I understand the issue with another point of failure but still prefer to go the route of an insulated backstay.
thanks
Todd
s/v Hestia
Old 12-16-2006
catamount's Avatar
catamount is on a distinguished road
The Hi-Mod insulator is supposedly the only one that is fail-safe. I've not used their backstay insulator, but have used other of their fittings. I would go with them over StaLoks or Norsemen...
Tim
Old 12-16-2006
Bill Mc's Avatar
Coastal Cruiser
Bill Mc is on a distinguished road
SSB antenna
My Personal preferance would be to not modify my backstay at all, but to install a split lead antenna that is removable should I have to replace the backstay or step the mast. The Product that I prefer can be found at
http://gamelectronicsinc.com/ssb.htm
This antenna coupled to an antenna tuner should do you proud.
Merry Christmas,
Bill KI4GSV
Old 12-16-2006
I would use insulated standoffs, and install the SSB antenna in parallel with the exisiting backstay. This is probably a better way to do it as it doesn't require modifying the rigging.
Old 12-17-2006
Bill Mc's Avatar
Coastal Cruiser
Sorry to all, I didn't check the link. the Sailnet forum took over the hyperlink by converting the keyword ssb to dirrect you to there store hence the confusion. I hope this is helpful to you all now
Bill
Old 12-17-2006
capecodphyllis's Avatar
capecodphyllis is an unknown quantity at this point
Any thoughts on a reliable tuner? My Palstar tuner works great but keeps breaking down and has become rusty. I would like a tuner that can be used with any radio.
Old 12-17-2006
SG-230 by SGC Electronics. http://www.sgcworld.com/
Been the standard for past 15-plus years by which all other tuners are compared.
Works with any radio.
Pricey, but well worth it.
Bill
Old 12-17-2006
Originally Posted by catamount
I would go with them (Hayn) over StaLoks or Norsemen...
Tim
May I ask why you believe Hayn mechanical fittings to be superior to Stalock and Norseman?
Just curious.
running backstay bkw Racing 8 12-09-2006 04:34 PM
calibrating a backstay adjuster tudmaester General Discussion (sailing related) 1 12-05-2004 10:18 AM
installing a backstay adjuster chris1514 Racing 1 08-19-2003 09:01 AM
Adjusting the Backstay Dan Dickison Seamanship Articles 0 08-07-2002 08:00 PM
