12-22-2006
Actually, the binder used in a lot of the fiberglass mat products is not compatible with epoxy. In many cases, it is specifically formulated to work with polyester/vinylester resins. Fiberglass cloth is much stronger and the longer fibers in it tend to lead to a much stronger repair.
