12-23-2006
The real problem with Carbon Fiber masts is that the resin does not conduct electricity well, while the carbon fiber does... so the heat from the resistance often causes the laminate to delaminate. However, since the damage is often internal to the laminate, it doesn't appear to be significantly damaged and then fails catastrophically, with little or no warning.
