12-27-2006
You can parallel them but it is not recommended. The 4Ds will charge more quickly and then potentially overcharge. You do not say what your charge rate is but it probably is less than 25% of capacity so it may be OK as you will not have sufficient charge capability to over charge, you may undercharge though. Regardless of that, it is not a good design.3 8Ds will be about 225 AH each total 675, 2 4Ds will be about 160 each 320 so you have about a thousand AH but not in a very usable package. You will be taking up about 8 square feet. Look at The Rolls modular 12 volts or the 6 CS25P the latter battery is 22x11.25 x 18.25 H That will take up 3.5 square feet and give you a premium battery package. They are 820 amp hrs but you won't miss the difference especially with all those cable connections and extra cells. 8ds and 4 4ds is 30 cells to maintain and lotsa cables, bad idea. If you have to have lower profile batteries and a thousand amp hrs you will be better off with a single bank of smaller 6 volts say in the 300-350 AH range. Without going into the details, I have been designing electrical systems for more years than I like to think about any more. Don't mix battery sizes, don't use a lot of cells and cables. There is never enough time or money to do it right but always plenty of both to do it over.
