Portable micro electric generators - Page 2 - SailNet Community
post #11 of 25 Old 12-30-2006
pigslo's Avatar
www.ibiblio.org/london/alternative-energy/windpower/literature/windpower-system.plans.bibliography
pigslo is offline
post #12 of 25 Old 12-30-2006
pigslo's Avatar
I found a site that had detailed plans for a small one that would work on a boat, I will keep looking. Above posts should get you started.
pigslo
pigslo is offline
post #13 of 25 Old 12-30-2006
pigslo's Avatar
http://www.instructables.com/id/E0T6...6NG5/?ALLSTEPS
one more that may be closer to what you need.
pigslo
pigslo is offline
post #14 of 25 Old 12-31-2006 Thread Starter
Owner, Green Bay Packers
Thanks for all the little piglets, I'll get on the case tomorrow.
sailaway21 is offline
post #15 of 25 Old 12-31-2006
ebs001's Avatar
Cam, if the 1000 is capable of 30 amps in as per your calculation it would certainly run a 20 amp charger that many people use. If however you have a 40 amp charger you would have to go to a larger generator. The generator size really depends on the output of your charger. The DC out put on the Honda 2,000 is also quite low as well, but it's not a particularily good way to charge your batteries anyway. It's a much better idea to use your smart charger which regulates the charging current to optimise battery charging.
Something else to consider is other AC loads you may wish to use from time to time like a Capacino maker and air conditioning, 2 items mentioned in previous threads, that would require a larger unit. Size matters
ebs001 is offline
post #16 of 25 Old 12-31-2006
Seinor Member
capn_dave's Avatar
Ahoy ebs001
The EU 2000 will provide 17 amps surge and 13 amps run at 120vac. A 40 amp smartcharger like the Truecharge will draw about 11 amps max. and taper off, down to about 1 amp. A 6000 btu Marine Air A/C draws about 6 amps run and 15 amps start. That is about the max for the EU2000 on start up. You have to run the EU2000 at full throttle to start the A/C unit with nothing else running.
I doubt if our friend has A/C on his boat, so the EU should be able to do what is asked. He could even run the microwave, a hotplate, coffee maker, etc. Just not all at the same time.
Fair Winds Oh!!! it is 77 degrees partly cloudy, wind about 9kts to go into the low 80's today
Cap'n Dave .......reporting to you live from Georgetown Bahamas
capn_dave is offline
post #17 of 25 Old 12-31-2006
moderate?
camaraderie's Avatar
Ebs...I've always known that size matters! but you're right if a 20AMP charger is all you need for your bank. When you get up into the 500A/H+ range on a cruising battery bank....it takes a lot of time to put your daily use back into those banks with just a 20 amp charger. My Heart smart charger inverter puts out 130AMPS before it starts tapering the charge and it is a pretty common piece of equipment on cruising boats but it does suck up the kilowatts in return for a fast charge.
camaraderie is offline
post #18 of 25 Old 12-31-2006
ebs001's Avatar
Cap'n D I think from what I,ve read that for surge current of short duration the EU2000 will go above the 2000VA rating and would run larger A/C units than a 6,000 BTU. In an earlier thread people were running 10,000 or 12,000 BTU units.
Cam, my point was one needs to match one's gen choice to one's loads, so before one buys think of loads now and in the future.
ebs001 is offline
post #19 of 25 Old 12-31-2006 Thread Starter
Before we get too far off the track, one of the major reasons that I was attracted to the little Yamaha 1000, or the Honda of the same size, is that it is physically small and light weight. 28 lbs !
Now, for that size and weight, you can do a lot of things, if not run your a/c. On a larger boat, it would afford you a completely independant charging system-to charge say your starting battery if needed. Given the size and weight I could see it being worth having to charge some specific items and then just toss it back in the bottom of a locker.
I know that I could go up to a larger unit, but that misses the point of having a small and unobtrusive unit in the first place. Let's face it, anything that weighs much over 50 lbs is going to stay right where it's put be it the garage, the bilge, or the back of the pick-up truck. At 28 lbs this is something that can easily be brought up on deck, walked down to the dock, carried ashore for a party, etc.... Frankly, I was surprised that they've gotten them down as small as they have with the output they have.
As usual, we have the camping, hunting, and fishing markets to thank for the impetus to design the product.
post #20 of 25 Old 01-01-2007
pigslo's Avatar
http://www.lookout2000.com/windpower/index.htm ...Here is the one I was looking for from a car alternator.
pigslo is offline
The Amazing Power of Water Generators Kevin Jeffrey Gear and Maintenance Articles 0 06-16-2003 08:00 PM
Electric Motors and Sailing Vessels Mark Matthews Gear and Maintenance Articles 0 11-17-2002 07:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
Portable Generators -- Hazardous? EscapeArtist Gear & Maintenance 0 07-23-2001 07:37 AM
