Wet Sanding - Page 5 - SailNet Community
post #41 of 47 Old 01-02-2007
timangiel's Avatar
Originally Posted by 1970Columbia34
If you maintain Awlgrip as they suggest its a great finish that will last a very long time.
How do they suggest you maintain awlgrip? Can you powerwash it? I need to do something with my boat and I'm interested in awlgrip.
timangiel is offline
post #42 of 47 Old 01-02-2007
ASA and PSIA Instructor
14 years and counting
FWIW. my boat has a Imron job that has had 14 years of hard use, and is very presentable other than at nose-lenght. See the pic and decide. An Awlgrip job can last more than ten years easy, especially if its white and not abused - white not only hides initial paint flaws, it also hides years of dings and scratches. I'd say the references to ten years mean "at least ten years..." and twenty is just as likely (go with white...)
sailingfool is offline
post #43 of 47 Old 01-02-2007
can't re member
On "megayachts" we generally have fairly high standards for paint. Most use Awlgrip (at least the six that I have worked on plus many others that friends work on) We generally expect it to last at least 5 years before repaint.(VERY high standards!) On my own boat I would expect double that.
Awlwash is a good, gentle soap and Awlcare is a polymer wax that really works to protect the paint from abrasive dusts.
Powerwashing seems like a bad idea to me although it may be ok at VERY low pressures like those provided by cheap electric washers. Get a soft scrub brush if you want your paint to last.
Light scratches can be buffed out with 3M Finesse it, deeper stuff with Perfect it, then finesse it, always followed with Awlcare.
Ditto SF regarding white paint. Especially if you are in the tropics.
yotphix is offline
post #44 of 47 Old 01-02-2007
"Sparkie"
j34035's Avatar
Deep caustic soak? Please elaborate.
DD
j34035 is offline
post #45 of 47 Old 01-02-2007
moderate?
camaraderie's Avatar
j34035...see the post from RichH n tis thread page 4.
camaraderie is offline
post #46 of 47 Old 01-02-2007 Thread Starter
Rich has indicated that a caustic soak can be accomplished by using a product called tuff-e-nuff.
Has anyone seen it sold anywhere lately? I've done numberous google searches with no results.
DM
dm567 is offline
post #47 of 47 Old 01-03-2007
"Sparkie"
j34035's Avatar
My bad. I should have read the entire thread instead of only the last page. Anyway, it sounds like good advice and will try it on my J that has quite a bit of gelcoat oxidation. Thanks.
DD
j34035 is offline
wet sanding johnnennis Gear & Maintenance 12 11-05-2006 08:05 PM
What shoes work for a wet ride in a dinghy sonomablue Gear & Maintenance 22 09-22-2006 03:09 PM
Mixing AGM and wet cell batteries Jonathan316 Gear & Maintenance 7 06-21-2005 11:16 AM
Little Wet Wed Boat jbarros Boat Review and Purchase Forum 2 01-14-2004 07:33 AM
Douglas Gill Wet & Dry Bags Dan Dickison Racing Articles 0 09-24-2000 09:00 PM
