Sabre 28 Fuel Tank - SailNet Community
Blogs
Old 12-03-2001
RickFagan is on a distinguished road
Sabre 28 Fuel Tank
Last year I purchased a 1974 sabre 28 equipped with an Atomic 4 engine with approximately 3800 hours of service. Last season and much of this season the engine performed flawlessly, however this September the engine began to stall out while underway. I found some water and small particles in fuel filter and although I had added fuel additives to the tank during the season, I suspect fuel contamination. Any thoughts on the process to solve this problem, i.e. is it necessary to drain the tank, is there a screen or filter upstream between or in the tank prior to the fuel filter. Thanks, Rick Fagan
Old 10-26-2006
Lecy is on a distinguished road
Did you try any water removal products like 'Heet'? You can usually find that in any parts store or gas station.
Because of the flammable nature of gasoline, emptying the tank can be tricky. Be sure to use a fuel transfer pump if you decide to pump it out.
Good luck-
Fuel tank problems Lusk Gear & Maintenance 18 01-23-2007 06:17 PM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 10:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 10:34 AM
old diesel fuel capedoryus Gear & Maintenance 1 12-17-2002 08:14 AM
T 34 fuel tank removal Peltier Gear & Maintenance 1 12-19-2001 06:44 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
