Old 01-03-2007
brmn54 is on a distinguished road
keel / cracks
Let me thank you in advance for any advice I receive. I have a C &C 35 MK III with a center board. When I purchased the boat two years ago it had some small crack around the keel and bottom connection. The cracks have returned and I was wondering what would be the best solution? There seem no to be any drainage from them, when hauled. Some one was suggesting 5200, but I don’t know. Thanks again.
Old 01-03-2007
CBinRI's Avatar
CBinRI is on a distinguished road
This should not be a big deal. I have a C&C 36 (on the market) that has been great and has avoided it, but it is not uncommon. My suggestion would be to search the term "C&C smile" on Google.
Old 01-03-2007
Thanks come to think of it I recognise that line.
Old 01-03-2007
BeneteauMark is on a distinguished road
My Beneteau 23 had the annoying habit of showing some cracking where the sealer was in the keel to hull joint. Per Beneteau's suggestion, I cleaned that area and filleted over the existing sealant with 5200. Has been working well for me.
Mark
Old 01-03-2007
Goodnewsboy is on a distinguished road
Many C&C boats have external ballast affixed to the hull by bolts.
The bolted-on keel is required to deliver the entire righting moment to the fiberglass keel stub across one half of its width. The narrower the keel attachment is, the greater the forces required to produce that moment. The tension members are the keel bolts, and the compression member is the outer periphery of the keel/hull joint on the side to which the vessel is heeled.
Net result is that the keel will move a little under the influence of these large forces and any rigid fairing material gets heavily compressed. To some extent this also applies in a fore and aft direction, but to a much lesser degree.
That's the cause of the C&C smile, and the flexible fairing solution suggested previously by using 3M 5200 or the like to fair the cracked joint is perhaps the only way to reliably avoid repeat cracking in the fairing area. An additional benefit is that, if carefully done and placed between the keel and the fiberglass, the flexible material helps to distribute the compression loads along the keel side, and that is a good thing.
Some will prescribe tightening the keel bolts. I'd be cautious. Excessive bolt tension adds to the compressive loads on the keel stub. Unless there are leaks or unusual gaps or movement, it might be wiser to leave well enough alone.
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
Winged Keels Pros & Cons OldGlory Boat Review and Purchase Forum 13 04-09-2002 05:51 PM
