Blogs
User Name
Old 01-02-2007
sailingwife sailingwife is offline
sailingwife is on a distinguished road
Loss of all transmission fluid
An interesting thing happened while out this past weekend. Our Perkins 4-154 with a Borg-Warner 71CR after heating up lost all transmission fluid into the bildge leaving us without any forward gear. After being towed back to the dock and filing the fluid again, all is well.
There was no wind and we had been running it at a higher RPM than normal to check for engine heating issues. We have only had this boat for less than 6 months so we are still finding these "issues".
Any thoughts or has this happened to anyone else?
Old 01-03-2007
pigslo's Avatar
pigslo pigslo is offline
pigslo is on a distinguished road
Transmission cooler not working and you boiled it out?
Old 01-03-2007
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
On some transmissions oil can blow out the dip-stick tube vent under certain conditions.
The fix is to drill an extra hole just below the threads near the top of the tube, but so that it's just inside the transmission housing. That way the tranny case can vent without pushing oil up and out the vent.
Sponsored Ad
Old 01-03-2007
Good information. One theory a dock mate had was that there was some type of pressure vent or overflow with a tube that created a siphon and once started went until all the fluid was drained.
Old 01-03-2007
jones2r jones2r is offline
jones2r is on a distinguished road
My instincts tell me that Pigs is on the right track. Any design or installation issues should have been sorted out much earlier.
One analysis is that either the cooling system, assuming there is one, has a problem, or something internal, such as a bearing, is failing, causing excessive heat generation.
It's possible that the fluid cooler is cracked and is leaking. I would look at it first. Flush it out and pressure test. There might be a hose or line leaking if the cooler is external to the transmission. This analysis is saying that the fluid escaped and then the trans overheated, not vice versa.
It's possible that if you were trying to push the boat past its hull speed, the trans was simply overloaded, with slippage causing the heating.
You will want to flush out all of the fluid to eliminate the residual burned fluid remaining from the overheating. Removing and flushing the cooler will help achieve that end. If, in the flushing process, any solid material is dislodged, the cooler should be replaced (discard the old one; it's NOT suitable for a spare) and consideration be given to inspecting the transmission.
Just my thoughts.
Display Modes
vB code is On
Transmission fluid LaLeLu Gear & Maintenance 15 04-11-2006 10:24 PM
transmission question almostbroke Gear & Maintenance 8 06-05-2004 02:06 AM
Transmission & Autopilot Fluid aphil138 Gear & Maintenance 0 07-24-2003 03:13 PM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 09:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
