01-07-2007
Camaraderie,
I have two completely separate systems, a 12V that has the Xantrax inverter and powers half of the A/C plugs in the boat. That battery bank has four 6 volt glass mat batteries that give me 440 amp hours and are wired to the 12V battery switch on bank 1, bank 2 controls the gen set start battery. Those batteries also run the autopilot, two 6000 lb rule davit winches and most of the lights on board. I also have a 12V Airex wind generator and a 130 Watt solar panal on the 12V side. The other system is the Heart Freedom 2500 with two banks of 6 volt AGM batteries with another 24V Airex wind generator. I assume the 24V banks are 220 amp hours each bank. These banks are wired to another battery switch that controls each bank. I usually run that switch on both and they seem to always be about the same level. The 24 V supplies power to the other half of the plugs, the two Raratan treatment systems (rarely used) the winlass winch and the A/C refrigeration system. The Link 2000 shows that when the Refrig is turned on, it draws around 50 amps to start then settles in around 20 amps. It also shows the battery charge rate to be around 70 amps when charging one 24V bank or 35 amps when charging both. If I turn on the refrig while charging the batteries, the inverter breaker will trip leaving the refig running off the batteries and draining the batteries. My father started building the boat in 1974 and launched in 1990. The inverters are new 5 years ago and the batteries are new this year. The 24V inverter function is working fine, its just the overheat E03 warning I get when charging the batteries.
I have two Crosby refrigeration systems one is labeled 24V but runs off the generator driven compressor so I would not say this is 24V as it will not run unless the gen set is running. The other system is labeled 110V and appears to be running off the inverter only.
I would like to add air conditioning to the boat and realize the gen set would need to be running or the shore power hooked up. I am considering changing the gen set from the old loud Isuza to a Panda Fisher unit that could run all the time when I am on the boat.
The E-03 overheat problem has only been occurring the last few days of the trip down and I am thinking that the cooling fan has gone out and that is why the unit is over heating.
Thanks for any help you can provide.
