Old 01-08-2007
aphil138 is on a distinguished road
Bottom paint on propeller?
I have my prop and shaft out of the boat while I install a PSS dripless packing. While I was inspecting the prop and removing the bottom paint from it, it appears that underneath the bottom paint is epoxy or some kind of grey primer. Is it usual for the salt water guys to paint their props and shaft? If so what do you all use?
fresh water guy
alan
Old 01-08-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Originally Posted by aphil138
IIs it usual for the salt water guys to paint their props and shaft?
While it is not unusual to find painted props on boats that live in saltwater, it is certainly not the norm. Further, the practice is not particularly effective, as most coatings are scrubbed off the prop (by water action over the blades) in a relatively short time.
"Clean bottoms are FastBottoms"
Old 01-08-2007
georgellop's Avatar
georgellop is on a distinguished road
.... check out "PROPSPEED".
George Llop
S/Y BANDOLERA
1958 41' PHILLIP RHODES BOUNTY II
BETAMARINE
DIESEL PROPULSION & GENERATORS
Mobile: (786) 443 5567
Fax: (786) 221 3986
Old 01-08-2007
k1vsk will become famous soon enough
The gray is more than likley Petit Zinc Coat Barrier Primer. It is used, as it's name implies, as a primer under copper based bottom paint, on metal surfaces such as props to minimize the potential for galvanic corrosion caused by the copper paint in contact with the bronze prop.
If you are going to repaint the prop, make sure you use it or something similar.
Old 01-08-2007
camaraderie's Avatar
moderate?
I've heard that if you use black magic marker and "color" your whole prop with it, the barnacles stay off. Anyone have any actual experience with this?
Old 01-08-2007
hellosailor's Avatar
Cam, I heard that Howard Hunt ran out and cornered the commodity market on black markers, he's not going to release the test results until he owns ALL the markers and can make another killing by selling them to the sailors who find out how effective this really is.
After five or ten years of the same rumor....wouldn't someone have already proved it worked, published it, and confirmed it by now? Or, is Sharpie repressing the information so their sales aren't regulated as "pesticides" ?
Old 01-09-2007
Wayne25's Avatar
Wayne25 is on a distinguished road
Interlux Primocon is a gray underwater primer for metals and a primer for antifouling paint. I used it this year on my Penn Yan inboard SS shaft and prop with good success.
Old 01-09-2007
moderate?
HS...didn't know the rumour was that old...just heard it a few months ago...Oh well...I'll go back to playing with my algae-x magnetic filter!
Old 01-09-2007
pigslo's Avatar
pigslo is on a distinguished road
I hear swine urine is very effective.
Old 01-09-2007
Pigslo-
Would this qualify as HAM...
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
Sick Bottom Paint? kmeeks Gear & Maintenance 4 05-16-2003 02:20 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
