Difference between 4awg and 4/0? Oh, about $15/foot and your pinky versus your leg! In wire sizing (typically used on a boat) it goes from about 20awg (I don't know where you would use this, but mention it) down to 1, then 1/0, 2/0, 3/0, 4/0, 250 mcm, 350 mcm. I think MCM means (MuCho Money)... but I don't have a freaking clue what the engineers think it means. I have not had to buy any of that and have gotten away with 4/0 on my inverter. Remember you have to use marine grade wiring (tinned).
If you are going to do, well, any wiring yourself on your boat PLEASE read some good books and seek the expertise of some folks that are very experienced. Nigel Calder is probably the best (Boatowners Guide to Electrical and Mechanical Systems... or something like that). You cannot miss it. The Electrical Bible is good too, but I cannot remember who wrote it.
I learned my stuf hands-on with my pops through rewiring houses then learned the differences that apply to a boat (and there are a bunch, not to mention direct versus alt current). Just please be caredul with the Air conditioner install or if you are going to run that kind of amps through a windlass.
You seem like a very nice guy and I don't want you in the Obits!!
Can some one explain what the diffrence is between say 4awg and 4/0awg wire. and which is need for a windlass?
It depends on whether you're going to put a battery forward, near the windlass or whether you're going to run it off the house bank. If you're putting a battery forward, then you could probably get away with 4 awg wire, to charge the battery with... and that might even be a bit overkill... but if you're going to run the windlass off the house bank... then you will want the 4/0 awg wire instead.
ed: Having checked the numbers from the OP first message, the 4/0 is barely good enough and I'd highly, highly advise putting a battery forward, and float charging it off the house bank or off a separate charger for it. A small panel might be a good option.
Sailingdog Telstar 28
If you're new to the Sailnet Forums... please read this POST.
CD what does intalling a windlass which is 12v have to do with my Air unit that will only run on shore power?
I was looking in the Lewmar manual for the Horizon 600 and it stats that if all the wireing for the windlass equals 90' then you need to use 4 AWG (16mm^2) wire, but you guys are saying that is to small. I plan to run the windlass from out house batteries. Thanks for all the help I know I ask alot of questions.
good page to refer to is located here. I believe the wire numbers that we're talking about refer to the the OP's windlass with a draw of 90-130 Amps...
He says he has an 100' run with a 12V load at 90-130 Amps. With 4 AWG wire, the voltage drop is over 6.5 Volts, which will lead to a fire. With 4/0 AWG wire, the voltage drop is 1.31 Volts, which is still a bit high, over 10%, but will probably work. I don't know where he is getting his 3% figure from though. The 2/0 AWG wire would result in a 2.1V drop...which is not a good idea.
I will make the guess that his windlass is a good deal larger than the Horizon 600 you're looking at.
I did not say 4awg was/was not too small. You would have to add up the round trip and check the charts. If they say 90 feet for 4awg, there you go. They know their product, draw, and probably oversize it 20% for safety would be my guess. Lewmar is a good name.
As far as the air conditioner, yes 110, but my point was to please be careful. Misswire something or a loose connection can sure burn down a boat quickly.
Hey, want to have some fun 1970? Start up a new thread right under the anchor thread. It should be called:
Crimping or Soldering? Which is best? It will go on through the night and well into the next few months. You can read it and go ahead and do what you were going to do anyway!
Why not put a dedicated AGM up forward, that is of the same type/size as the ones in your house bank. That would certainly make dropping one in for the other easier, and AGM batteries are better at holding their charge over long periods of time, which is often the case with a windlass... you drop the hook, stay a few days, raise the hook, make a long passage... etc.
Because I have a perfectly good about-to-be surplus charger and perfectly good and brand new in 2006 flooded batteries. I may change my mind on this, though, as the ideal thing would be to have identical batteries all around.
I am under the impression that an old-school charger won't maintain the AGMs properly: am I wrong here?
My old cabin runs on the '73 sloop are at best 18 or 20 gauge, which is stupid with 12vdc incandescents, but perfectly fine if you switch to bayonet-mounted LED clusters.
I won't even get into the original brass fuse box on the AC side or the 10 gauge Romex wiring. Fresh water thinking.
Valiente...AGM's take the same charging routine as Flooded. I don't know what you mean by "old school" but as long as you charge bulk at about 14.3 and have a float stage as well you should be OK with anything that works well for flooded deep cycle batts. But...if you've got a 2nd charger and batt already then I guess it is a non-issue for you!
