Old 01-11-2007
1970Columbia34's Avatar
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Bow Roller?
I am looking for a bow roller that will work with a 22-35lb Delta Fast set anchor, and work with the anchor being pulled up by a Lewmar Windlass. Anyone have a recomendation? I have looked online and there seems to be so many to choose from. Thanks.
Old 01-11-2007
camaraderie's Avatar
moderate?
Columbia....there are many rollers that will work with Deltas...especially since they drop pretty well with the tip weight concentration. The real question is which roller will FIT on YOUR boat and bow/windlass configuration and how much overhang you want.
After you know the room you have to work with then yu can check here for a variety of options and complete technical/dimensional specs:
http://www.windline.com/rolleroverbow.html
Old 01-11-2007
Have a Steel shop make you one!!! Real easy and cheaper probably!!
Old 01-11-2007
moderate?
Giu...definitely not cheaper here!! Been there...done that!!
Old 01-11-2007
The real problem will be having a bow roller that is of the right dimensions to properly fit on your foredeck. Having a properly fastened and secured bow roller is important, as it takes a fairly heavy load when you're at anchor.
I agree that a custom one, of the right materials is not going to be cheaper than an off-the-shelf one. It'll probably work and fit better...but it will definitely cost more.
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 08:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 07:00 PM
Bow roller - C&C35 thomsonjd Gear & Maintenance 1 12-23-2001 02:45 AM
