Best way to soundproof engine compartment? - Page 2 - SailNet Community
 2Likes
post #11 of 28 Old 11-12-2013
mitiempo's Avatar
Re: Best way to soundproof engine compartment?
You have resurrected a very old post but here is a link to the product I sell in Canada. I am not sure where you are located. The link is from Jamestown Distributors in the US. It is a high density fireproof foam in 2 layers with a mass loaded vinyl between them. It is covered with a foil surface and a which is easy to keep clean. It is sold with a mounting system and usually contact cement is used as well. It should be available where you are located. Hope this helps.
Soundown Composite Insulation Vinyl/Foam Sheets
Here is a link to a pdf showing the product details.
http://soundown.com/Section%202%20PD...nyl%20Foam.pdf
Brian
mitiempo is offline
post #12 of 28 Old 11-12-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
I lined the engine compartment hatch with 1" foil faced fiber-glass duct board. Creative use of *real* aluminum foil duct tape sealed the edges and reinforces the mastic which fastens it to the 1/4" ply.It works so well that I intend to apply it to the entire compartment....some day . The compartments bulkheads are plywood; so a few screws with fender washers to keep it in place till the mastic sets is all it will take. Then a contortionists game applying tape to the joints/seams.....
Avail. at most HVAC suppliers and possibly by order at big-box stores?
HTH
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #13 of 28 Old 11-12-2013
mitiempo's Avatar
Without the mass loaded high density layer the low frequencies of the diesels will not be reduced to a low enough db level.
jrd22 likes this.
Brian
mitiempo is offline
post #14 of 28 Old 11-12-2013
I used the Soundown stuff, 1" thick, except under the cockpit sole, where I doubled it to 2". Honestly, the main noise is now from the exhaust, when under way. I would seriously like to do something about that. I have been wondering if my 30 year old silencer box is losing some effectiveness.
MarkSF is offline
post #15 of 28 Old 11-12-2013
Missingyou's Avatar
This is same stuff I have been considering for my generator cabinet. It's one of my winter projects. Unfortunately it's a bit on the expensive side, but it is the correct product to use.
Missingyou is offline
post #16 of 28 Old 11-13-2013
An ambulance boat is such a novel concept.
Can you tell us if this is all a custom build?
What the range and speed are, and the intended area of operation?
hellosailor is offline
post #17 of 28 Old 11-13-2013
GreatKetch33
Deric's Avatar
What about neoprene ? It is supposed to be oil resistant, water resistant; it's the same material scuba diving suits are made.
One can purchase sheets: various sizes and thickness.
Deric is offline
post #18 of 28 Old 11-13-2013
Asleep at the wheel
jimgo's Avatar
Deric, I think neoprene would be good for damping vibrations, but it doesn't have the mass to absorb and dissipate the sound energy.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #19 of 28 Old 11-13-2013
Dave_E's Avatar
There are 2 kinds of marine engine compartment insulations. One is for gas, the other for diesel. I just re-did my doghouse... it's not that hard. Good sturdy putty knife took off the old stuff. Sanded down the old glue spots with big grit paper. Use spray glue in a can MADE FOR FOAM. Found a can at my local hardware store. The new insulation (as mentioned) is pricey. Don't skimp if you can, you'll be glad you didn't. Cuts with a good heavy pair of scissors (might have to borrow your neighbor's jocko kid though) :-)
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #20 of 28 Old 11-13-2013
Neoprene foam is dense, but it is also expensive and flammable. And the less expensive "chemical blown" neoprenes tend to degrade faster in heat, i.e engine rooms.
If it was the right material for the job you'd see it used on production boats.
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 09:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 09:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 09:00 PM
