Garmin 498 C Sounder Opinions ? Transome mounted Transducer? - SailNet Community
Blogs
Old 01-14-2007
chuck711 is on a distinguished road
Looking for info on Garmin 498 C Sounder. Any suggestions or opinions
It can be bought with a transome mounted transducer. Opinions?
Not knowing I would prefer a standard thru hull mounted transducer.
Any suggestions?
Good place to purchase?
Thank You
Old 01-14-2007
The Garmin units are pretty good... I use a 192C on my boat. The 498C has the coastal charts built in to the ROM. If your boat has a solid hull, you may be able to mount the transducer internally, using an oil-filled mount, and not drill any holes through the hull. Standard through hull or an internal oil-mount are preferable to a transom mount generally. They're more reliable and less subject to damage and other problems.
Defender.com and pyatch.net generally have pretty good prices on electronics.
Old 01-14-2007
camaraderie's Avatar
moderate?
http://www.defender.com/product.jsp?path=-1|344|69977|320684|320686|328456&id=609515
Here's a link to it at Defender.
Garmin vs. Raymarine - opinions from users? SamNetherly Gear & Maintenance 3 05-13-2005 08:13 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
