01-15-2007
The other reason to seal wood when, especially if it is in contact with metal, is that any salt water that is absorbed will cause accelerated corrosion where ever the wet wood is in contact with metal. This would cause pinhole leaks in the tank, all along the bottom... which is also something you want to avoid with a gas tank.
