Foul Weather Gear for Small Dudes - SailNet Community
 8Likes
post #1 of 21 Old 03-16-2017 Thread Starter
Last season I thought it was finally time to get serious a get myself some real foul weather gear. I found a good deal on West Marine’s Third Reef Jacket, but found that--even though I was well within what their sizing chart called a small--it was much too big and boxy for me. I returned it. As a rather small guy (5’5’’ - 135lbs) I am no stranger to this issue. I should have known better! Size small clothing items (even when the provided sizing charts indicate that they should work) rarely fit me well.
Anyway, I’d really like to get my hands on a jacket for this season. My question, of course, is are there any known manufacturers of foul weather gear that make things in a trimmer cut? Unfortunately, there are no dealers of such things close by me where I could actually try stuff on.
Also… do I even have a prayer of being able to find such an item for around the $150 mark like the Third Reef Jacket?
Thanks,
T.Bird
Be humble for you are made of earth.
Be noble for you are made of stars.
T.Bird is offline
post #2 of 21 Old 03-16-2017
krisscross's Avatar
Re: Foul Weather Gear for Small Dudes
Have you tried their women's sizes? They are usually much better fitting and span more sizes.
MarkofSeaLife likes this.
Plato
krisscross is offline
post #3 of 21 Old 03-16-2017
$150 for a good jacket probably isn't realistic. It's possible if you find a clearance sale or something, but it's going to take a lot of time to find one that cheap. And no the West Marine one is not what I would consider a high quality piece of gear.
Take a look at the Zhik Kamina (sp) at about $200. For your height you would probably need the XS.
Greg
Stumble is offline
post #4 of 21 Old 03-16-2017
Keep in mind that you almost never wear the jacket by itself, even in the tropics.
Size it for a layer or two underneath, sometimes more if you are around the Great Lakes.
To me this is the reason for the extra bulk.
SVTatia is offline
post #5 of 21 Old 03-16-2017
Tbird, there are all sorts of Gore-Tex Extreme Wet Weather guaranteed gear that work for sailing. Genuine Gore-Tex with a guarantee is also guaranteed for life, if it leaks Gore will replace it if the manufacturer doesn't. And Gore comments that a lot of the cheap "Gore-Tex" sold on ebay and shipped from China, is simply counterfeit junk. If you're not spending a month in mid-ocean, it might be very much worth looking at.
But you're lucky to be a small, when there is a clearance sale (usually in fall, not spring) and a model change, there are usually smalls and xxLs available, nothing else.
I'd also suggest looking at women's sizing. At least one company from New Zealand used to put all their zippers in "women's style" so depending on brand, you might or might not een notice the zipper is on the wrong side by US standards.
With any of it, you'll need to try it on, the fit of the hood and collar is a very personal thing.
hellosailor is offline
post #6 of 21 Old 03-16-2017
I typically find Helly Hansen to run narrow or small for the size. This may be the result of what is expected to be worn beneath, or not.
I have precisely the opposite angle. I need to buy my foul weather gear from the NFL.
Jeanneau 54DS
Minnewaska is offline
post #7 of 21 Old 03-16-2017
I have a quality Grunden jacket for warmish weather rain....ran maybe $150 from fisheries supply.
Also an offshore Gill for more nasty stuff that I found on Amazon at 1/2 price....a UK dealer was dropping that line.
You could also check ebay for resellers of closeouts.
Having good quality gear will keep you from truly hating life when things aren't so nice out there.
I used to ride bikes in rain, sometimes for hours on end, and after it's all said and done...you spend the bucks and get good stuff.
Torture, even in short doses, is still torture...
RegisteredUser is online now
post #8 of 21 Old 03-16-2017
I'll 2nd the womens suggestion.
Some may offer something like youth sizes.
post #9 of 21 Old 03-17-2017 Thread Starter
Yeah... I guess my standard of quality is pretty low. I'm just looking for something nicer then the old worn out raincoats I have been wearing, and hopefully something with a few sailing-ish features (nice cuffs to keep some water out, tall collar, visibility, etc.)
I think my next step will be following the advice of those recommending Women's sizing. I've had to go that route before with various things. The trouble is that sometime the female proportions of some of those garments fit a little awkwardly on my small yet still generally man shaped frame! Worth a try.
Thanks for chiming in everyone!
T.Bird
T.Bird is offline
post #10 of 21 Old 03-17-2017
Tanski's Avatar
I find cheap"gore-tex" clothing to be false economy, never had any of it last more than a couple years before it starts leaking. Had the membrane separate from the fabric, taped seams come undone. The DWR of the fabric starts wearing off very quickly and you have to respray it and the new stuff isn't near as good as the old sprays.
Bite the bullet and buy decent stuff and you'll be comfortabe for years to come vs buying over and over again when you get fed up of being wet.
If you do want to go cheap skip the breathable fabric and buy a non breathable coat for the same price.
One other thing, breathable fabrics ONLY work if the humidity inside the coat is higher than outside. One thing the manufacturers never seem to tell you. They also only pass water vapour, if you're sweating more than the fabric can handle you will still end up soaking wet.
That is a horse head in the box. Not an alien!
Tanski is offline
WM Foul Weather Gear Silversailor Gear & Maintenance 29 01-08-2014 12:21 PM
Foul Weather Gear AZBlueDevil83 General Discussion (sailing related) 10 04-14-2009 02:19 AM
Foul weather gear voice3 Gear & Maintenance 14 02-05-2009 07:29 PM
Foul weather gear locrian13 herSailNet 30 08-01-2007 06:19 PM
Foul Weather Gear crl21 Gear & Maintenance 2 08-09-2006 12:24 PM
