Old 01-15-2007
trantor12020's Avatar
trantor12020 is on a distinguished road
Prop nut size
I've a 15"Dx10"P 2-blade prop on a 1" shaft. I need to get the right ring spanners for it, does anyone know what the nut size is? The AF (across flat) dimension.
Old 01-16-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Why not just use a Crescent wrench (adjustable wrench)? That's what they used on my boat when they changed the prop in the water.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 01-16-2007
Yes, adjustable spanners will be my backup plan if I couldn't arrange for ring spanners. Been taught in school to always use ring spanners where possible, less chances of slipping and hurting hands and also less chances of rounding the nut edges.
Old 01-16-2007
PBzeer's Avatar
Wandering Aimlessly
You have a Hunter 326 don't you? If so, e-mail Hunter, or check the HunterOwners website. Just eyeballing it, the nut on my 1" shaft was about 11/16 or 3/4.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 01-16-2007
Yes! I've a H326. HAHA, its so easy to get answers here, somehow I just forgot about Hunter! I'll knock off an email to them. cheers!
Old 01-16-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
You can also call a propeller repair shop for the nut size, as they will have the nut on a shelf and can measure it.
Whether or not you end up using a ring spanner (I suspect that is what we Yanks call a "box wrench") or something else, like a pipe wrench (which I recommend,) it should be at least 18" long. It will be difficult to properly torque the nuts with anything shorter.
"Clean bottoms are FastBottoms"
Old 01-16-2007
jones2r is on a distinguished road
You may want to consider replacing the nuts while you're at it. If there's any wear or, particularly, corrosion, the threads will have lost much of their retaining capability.
Incidentally, an 18" Crescent spanner will be much stronger than the correspondingly-sized open-ended spanner; don't worry about it opening up. FastBottoms is in the business; his recommendation for a pipe wrench (wouldn't know your terminology -- what's the British term for pipe? I believe we have spanner understood) would be well-founded and based on his personal experience.
Old 01-26-2007
Ok, got an answer from Hunter. Its 1 3/16" AF. I haven't found a ring spanner yet but have a metric size adjustable. If only I could lay my hands on an imperial size adjustable spanner. hmmm.
Changing prop underwater trantor12020 Gear & Maintenance 16 03-03-2007 12:02 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
what size prop?? stevfran Gear & Maintenance 1 01-30-2003 07:16 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
Proper Prop size for Cat 30 gfeier Gear & Maintenance 0 08-20-2001 04:52 AM
