Blogs
User Name
Old 12-12-2001
windancer1 windancer1 is offline
windancer1 is on a distinguished road
Flooded battery installation questions
I hope someone out there can help me. I am would like to install two deepcycle 6volt golf cart batteries on my boat and I was wondering how far can I tilt them before the plates are exposed. The ones I am installing are Westmarine mod.# 8l16. They are very tall. And as my boat has a large rig, the toe rails are in the water often.
Any help would be appreciated.
Dave R.
Old 12-13-2001
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enoughJeff_H will become famous soon enough
Normally this is expressed as an angle and you should be able to email West Marine and get an answer. http://www.westmarine.com/webapp/commerce/command/ExecMacro/home.d2w/report
And then pick product advice.
Good luck
Old 12-16-2001
yandina yandina is offline
yandina is on a distinguished road
I wouldn''t worry about it. Keep them topped up to the recommended level and they will work fine. You would have to spend a significant percentage of the time at angles of over 40 degrees and even then the percentage of plates exposed would be minimal.
Golf carts are designed to negotiate some pretty steep slopes too.
Colin Foster ^-^
Sponsored Ad
vB code is On
Starting Battery vs. House Battery GarrettK Gear & Maintenance 18 10-26-2004 11:58 AM
Battery loses charge svzephyr44 Gear & Maintenance 1 09-28-2004 03:20 PM
Battery Charging Question gwp Gear & Maintenance 6 05-08-2004 12:28 AM
Adding 2nd Battery...help redbeard58 Gear & Maintenance 2 03-03-2003 07:13 PM
Dual Battery Installation Urband Gear & Maintenance 1 03-25-2002 09:57 PM
Page generated in 0.4417 seconds (59.62% PHP - 40.38% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
