transducer thru-hull problem / epoxy glass build - SailNet Community
post #1 of 4 Old 03-22-2017 Thread Starter
So i removed my old thru hull fitting which had a beveled flange. My new transducer (airmar p319) has a flush mount flange. Only about half the Ducer flange will touch glass due to the bevel on the hole bottom. My boat hull is solid glass. Im plan to seal with 4200 since its easier to remove in the future. I also have 5200 avail.
Is it possible/strong enough to just fill in the bevel flush with the hull/hole opening with epoxy only or should i really be glassing the hole in and recutting. The hole size now is perfect for new ducer just the bevel on the hole im worried about.
Thoughts on 4200 or 5200 and why?
Thank you
Sail LN23
sail LN23 is offline
post #2 of 4 Old 03-22-2017 Thread Starter
Re: transducer thru-hull problem / epoxy glass build
Since i cant edit i will say the flange on the ducer is flat not sure if thats called flush mount
Thank u
post #3 of 4 Old 03-22-2017
overbored's Avatar
the bevel should be filled with thickened epoxy. or epoxy putty. you want the support of the fiber glass close to the 2" diameter so when you tighten the nut there is no bending of the sensor flange. I would use 4200 as 3M recommends it over 5200 for fiberglass to plastic fittings and it is good for under water use, also removable.
"GOLD RUSH" PRINDLE 16
overbored is offline
The Following User Says Thank You to overbored For This Useful Post:
sail LN23 (2 Weeks Ago)
post #4 of 4 Old 2 Weeks Ago Thread Starter
Thank you all for the advice. I built the hole down with epoxy then used a 3 inch sanding disc to create a flat surface for the transducer flange. I used 4200 to glue it in perfectly flush against the hull. Very happy with the results, on to the next project.
sail LN23 (Trailer Sailor)
Re-build cost if you have just the hull Shortnsalty General Discussion (sailing related) 16 08-13-2014 11:51 AM
How thick does a hull need be? Or is more glass always better? sailingbud Sailboat Design and Construction 5 10-10-2010 01:59 PM
transducer problem?? dvpamenter Gear & Maintenance 3 08-11-2008 08:33 PM
Carbon + Epoxy and Glass + Polyester Idiens Gear & Maintenance 26 05-09-2007 11:38 AM
old glass hull v. new glass hull shmangasarian Boat Review and Purchase Forum 5 10-30-2003 10:20 AM
