Hot Water Heater Usage - Page 4 - SailNet Community
post #31 of 39 Old 01-21-2007
A little less cheek
ianhlnd's Avatar
Talking
I know this is an old thread and you've been given practically every solution possible, but I didn't see anything mentioned about a defective or lack of a thermostat. Heat exchangers do sometimes fail, not regularly, but thermostats do. Was it taken out? You didn't mention the temperature your boat operates while under motor. That's the first thing I'd look at to see if there's a problem.
"I realize the instant one would only be good at the dock. What I'm wondering, is if I really need one at all."
Please, for the sake and sanity of crew, get one, any one
ianhlnd is offline
post #32 of 39 Old 01-21-2007
humble pie rat
CapnHand's Avatar
Why would anyone need a hot water heater? Why would you want to heat water that's already hot?
What you may want is a COLD water heater; much more useful.
CapnHand is offline
post #33 of 39 Old 01-21-2007
Then explain to me, how am I, as a foreigner going to understand NEAR MISS???!!???!?!?!
Giulietta is offline
post #34 of 39 Old 01-21-2007
Larry the heat exchanger HW heaters are pretty reliable. You already have the footprint and the plumbing. Tanks aren't that expensive. We are full time liveaboards and shower aboard anytime the crew don't care to walk up to the marina when we are in port..which is to say, frequently. Shore power heats fast enough to get everyone (2 adults, 2 kids) done in about 1 1/2 hrs from switch on to wiping down the head. Running the engine actual gets the water hotter and does well enough for the entire crew to shower at the end of the day. We use an Atlantic Marine 6 gal unit. Has a 5 year warranty and has worked fine. The boat originally discharged into the bilge with all the attendant problems mentioned. I tried unsuccesfully to use a Jabsco Par Max 3 Shower sump pump and after 3 replacements I went to a Whale Gulper model and problems ended. I use a Y valve that connects the shower sump to the "Drying bilge pump discharge line" works great. Might add that the crew is well trained in water conservation even though we have 150G. Also with a 4-107 we produce sufficient heat with the exchanger pretty quickly. Water temps are in the mid-upper 40's right now. Hope that helps.
Regards,
Red
Loewe is offline
post #35 of 39 Old 01-21-2007
can't re Member
captlar's Avatar
Red - John is the stinky one. I have the IsoTemp. You do make a good point. I had to rip out a perfectly good setup, create new space in a new location for the IsoTemp and solve some related space problems. Those modifications drove up the price - the IsoTemp was around $800.
One last point on the instant heaters - When I was looking, most were usable only at one location so no HW at galley. If going with instant, read the specs carefully. NowI smell good and my galley is clean.
John - if it can't be repaired, replace what you have with a new, well insulated tank and make your crew happy.
Larry
"We have met the enemy and he is us." - Walt Kelly's Pogo
captlar is offline
post #36 of 39 Old 01-21-2007 Thread Starter
Wandering Aimlessly
PBzeer's Avatar
Wait a minute now, I'm not dumping anything in my bilge.
I am my crew. So I only have to worry about what works for me. Not to mention what works for my wallet. And that's probably the main consideration at this point. After redoing all the wiring on the boat, complete with new distribution panels (which is what led to the question on water heaters), new A/P and davits, another 5 to 6 hundred seems like a lot. There is a Force 10 for around $200, but that would be iffy on space.
Mostly though, this thread was a way of thinking outloud. So far, I've replaced with new, rather than try to extend 20+ year old parts and I don't want to do anything half-a$$ed. It may only take me a day to do something, but I've generally thought about it for at least a week before deciding to do it. I not only want to put it in right, I want to be able to take it out easily if necessary. Something the PO's gave no thought to.
I appreciate all the responses. It's one thing to think about something, quite another to get "real life" input. What works in theory, doesn't always hold up so well in reality.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #37 of 39 Old 01-21-2007
humble pie rat
CapnHand's Avatar
NEAR MISS is like France in the World Cup finals.
CapnHand is offline
post #38 of 39 Old 01-21-2007
moderate?
camaraderie's Avatar
BIG MISS is like Portugal in the World Cup! ....or maybe WMD's???
camaraderie is offline
post #39 of 39 Old 01-21-2007
moderate?
John...getting back to your actual thread...
One thing I wanted to mention if you DO decide to run heat exchanger lines from the engine back to the heater exchange...be sure to put stop **** valves in place on the ENGINE end of both out and return lines. That way...if you have a clamp fail or hose burst and lose your water/coolant, you can close the valves, re-fill and go start the engine.
I think I've said this before somewhere, but it bears repeating as so many installations I've seen just clamp the hoses on.
hot water heater firstafair General Discussion (sailing related) 12 11-09-2006 11:25 AM
hot water heater question primerate84 Gear & Maintenance 8 10-19-2006 09:24 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 09:00 PM
