Blogs
User Name
Old 11-27-2007
nightowle nightowle is offline
nightowle is on a distinguished road
portable heater or de-humidifier?
Now that it's getting colder here in Seattle, dampness is ready to set in. Am I better to get a heater or dehumidifier that I'll use on shore power in order to reduce mold, etc? I was thinking of using a Davis Air Dryer. http://shop.sailnet.com/product_info...keywords=Davis
Right now I just have some of the 'pellet' products that pull some moisture from the air. I'd like to get some opinions on this subject.
Thanks
________
S/V Nagual
O'Day 27
Seattle, WA
Old 11-27-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Are you going to be using the boat, or living aboard the boat? If not, then the best way to get rid of humidity and prevent mold is to ventilate the boat well and to use a big package or several smaller ones of DampRid, or something similar.
Electrical heaters are one of the biggest causes of fires on boats, and unless you're living aboard, or sailing the boat regularly, leaving a heater on long-term is a rather risky proposition IMHO.
If you're new to the Sailnet Forums... please read this POST.
Old 11-27-2007
thekeip thekeip is offline
thekeip is on a distinguished road
I leave light bulbs on during cold winter nights...25w up fwd, and 40w in maim cabin....
Sometimes I use a 'Gold-Rod' under the engine and leave it on at night. It's rated 12w or so and seems to keep the bilge dry. I'm not sure it's doing anything, really, but make me more comfortable.
Howard Heiper
Sea Quest
Berkeley
Sponsored Ad
Old 11-27-2007
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
We use a small dehumidifier similar to the one you mention, and do notice the improvement inside the boat. However we were told to keep a little heat on too otherwise the cooling plate in the dehumidifier will freeze and it will stop working.
I check the boat regularly - twice a week at least, and leave the heater on "warm" rather than the hotter settings... keeps the boat at around 12 - 14C when it gets close to 0C outside. The reservoir in the dehumidifier gathers about half a liter(quart) in a week of soggy west coast weather.
Overall we're quite happy with this arrangement. SD is correct in the need for ventilation, so if security concerns allow, leaving a hatch cracked somewhere helps keep the air moving. We have also, in the past, hung a couple of computer "muffin" fans to move air around.
Old 11-27-2007
The solar ventilators, like the Nicros, are pretty good at getting/keeping the air moving in and out as well.
Old 11-27-2007
Valiente Valiente is offline
Valiente will become famous soon enoughValiente will become famous soon enough
A diesel bulkhead heater on low is surprisingly good at drawing the damp, inside air and sending it out the chimney. The key is circulation...if you draw in even damp air, your breath will make it damper still unless you can vent it positively out.
I have recommended the book "The Warm Dry Boat" before. As it was written by a guy living in B.C., its advice should be applicable.
Old 11-27-2007
TAK's Avatar
TAK TAK is offline
TAK is on a distinguished road
I was discussing this topic with a dock neighbor who has run 24/7 during the winter for several years a pair of West Marine portable heaters at the low setting (see below..)
They are a low profile so tipping over does not seem an issue and they have a switch that turns on if the temp falls below 38 degrees.
Was wondering if any one else has used them?
http://www.westmarine.com/webapp/wcs...2&classNum=743 )
s/v Mahalo
Caliber #4065
Old 11-27-2007
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
We've been using that heater for about 8 years and have found it to be reliable. However, we only use it when we're aboard and attached to shore power -- I would worry about leaving any electric heater unattended for long periods. It does a fair job of taking the chill off in the cabin of our 31 footer, but not nearly as good a job as our Dickinson Newport P9000 propane fireplace.
Old 11-27-2007
dave6330 dave6330 is offline
dave6330 is on a distinguished road
We just vent the boat with the solar vents and a mushroom vent on the forward hatch when we're not on board. The only thing running off of shore power when we're not "camping out" on board is the battery charger. We have one of the small electric heaters we use up front and an Espar forced air heater to keep things cozy when we're on the boat and (knock on wood), we've had no problems with dampness. When we leave the boat, we prop up the cushions from the v-berth (where we sleep) and open all the cupboards to allow venting. There's always water in the bilge, but we have a keel stepped mast and the couple of inches of bilge water is fresh, so I don't worry about it (much).
Old 11-27-2007
Good advice and suggestions so far. I am not sleeping on the boat and will use it infrequently during the winter, although I check on the boat about once a week. I have been keeping a 100 watt bulb on connected to shore power and have a couple of the small dry-eze tubs. I was thinking about also using a small fan I have to move the air, but was concerned about the safety of that.
________
S/V Nagual
O'Day 27
Seattle, WA
Display Modes
vB code is On
winterize hot water heater? saltypat Gear & Maintenance 6 10-26-2007 12:47 PM
Diesel Heater Carboning SV_WholeHeart Living Aboard 3 04-06-2006 02:57 AM
installing duct system for diesel heater and air conditioner levenezia Gear & Maintenance 1 09-25-2004 04:20 AM
Water Heater By Pass Valve MHRitter Gear & Maintenance 2 10-31-2002 10:41 AM
Onboard Heater Sue & Larry Gear and Maintenance Articles 0 10-15-2001 09:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
