Oil Analysis - SailNet Community
 2Likes
post #1 of 20 Old 1 Week Ago Thread Starter
davidpm's Avatar
Oil Analysis
We just sold a boat. I have included the oil analysis. We had to knock off a 1,000 to close the sale.
How lucky did we get? I'm not a diesel guy but the analysis looks like trouble to me.
What do you think? This is an 80's boat with original Univeral.
Interpretation Text:MODERATE AMOUNT OF IRON AND DEBRIS VISIBLE UNDER MICROSCOPE. SOME DEBRIS APPEARS COPPER/ BRONZE. IRON(FE) APPEARS ELEVATED. RESULTS MAY BE REFLECTIVE OF THE BREAK-IN PERIOD. MORE SAMPLES ARE NEEDED TO ESTABLISH A TREND. ALL OTHER LEVELS APPEAR ACCEPTABLE FOR UNKNOWN HOURS ON OIL. PLEASE INCLUDE HOURS WITH FUTURE SAMPLES. SUGGEST CHANGE OIL AND FILTER(S) AND RESAMPLE IN 50 HOURS TO MONITOR.
Interpretation Text:ELEVATED POTASSIUM(K) MAY INDICATE A MINOR COOLANT LEAK. POSITIVE REACTION TO TEST FOR GLYCOL. CHECK FOR CRACKED CYLINDER HEAD AND/OR LEAKING GASKET OR SEAL. ALL OTHER LEVELS APPEAR ACCEPTABLE FOR UNKNOWN HOURS ON OIL. PLEASE INCLUDE HOURS WITH FUTURE SAMPLES. STOP UNIT IMMEDIATELY IN ORDER TO CORRECT PROBLEM(S).
davidpm is offline
post #2 of 20 Old 1 Week Ago
Cruising at a snail pace
Re: Oil Analysis
I think except for the potassium level, which is a real measurement if it had a number, the rest is just word ******** (the feral matter that comes out of the rear of a male cow).
But for a buyer who had enough question in their mind to do the analysis I think you got off cheap.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #3 of 20 Old 1 Week Ago
MarkofSeaLife's Avatar
Dock
Re: Oil Analysis
Love their marketing exercise: Send More Samples! Send Samples Every 50 Hours.... 40 hours.... every 25 minutes.
Buy our Bulk Discount pack of 1000 samples for $10,000!
Buy buy
RegisteredUser likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #4 of 20 Old 1 Week Ago
Master Mariner
capta's Avatar
Re: Oil Analysis
"POSITIVE REACTION TO TEST FOR GLYCOL." Pretty lucky, IMO. But honestly, had our engine not had only 30 hours on it I would have preferred to swap it out for a Gardener right from the start. Not that I'm not taking good care of this one. But one day......
facebook.com/svskippingstone
Our Videos;
capta is offline
post #5 of 20 Old 1 Week Ago
Re: Oil Analysis
Very
Philabaco is offline
post #6 of 20 Old 1 Week Ago
Re: Oil Analysis
Who did you send the sample to for analysis? I use Blackstone Labs. I can call on any sample and speak to a tech who will break down the numbers into real world information. For example, lower than expected flash point indicates fuel in the oil however, it does not necessarily mean you have a problem. Extended idle time, cold sample etc., can cause anomalies in the sample.
Having a history on the samples is always good, without a base line it is difficult to develop a sense of what the engine is really doing. When we do aircraft samples we have a significant advantage as we have engineering data on the engines and can predict very accurately what the sample "should" look like.
Endless Summer is offline
post #7 of 20 Old 1 Week Ago
flyingriki's Avatar
Re: Oil Analysis
I too use Blackstone for my airplane and rice rocket and will on the next boat. Great guys, great service, good reporting and trend monitoring.
Thinking it's just a scam to sell more sampling is plain foolish. Excellent engine monitoring at the microscopic/chemical level. We also check screens and filters regularly for larger evidence of problems. Guessing on a boat, if like my last one, the sampling would be fairly infrequent due to lack of hours. I don't think I put more than one oil changes worth of hours on mine in the 8 years I owned it. Won't let the next one go so long as time affects oil too. Maybe more critical on aircraft but just the same......
Sample Report:
http://www.blackstone-labs.com/report-explanation.php
flyingriki is offline
post #8 of 20 Old 1 Week Ago
Learning the HARD way...
eherlihy's Avatar
Re: Oil Analysis
If it was the M25 on the O'day, I suspect that someone installed a new raw water pump (iron and copper/bronze), and the alternator bracket was recently replaced (resulting in coolant contamination of the oil from the exhaust manifold bolts).
It sounds like you got ~$30K for a plain-vanilla O'day 35 (no modern electronics, no traveler, no dodger no bimini) which seems about right. In what condition were winches and the sails? Was this the shoal-draft version?
eherlihy is offline
post #9 of 20 Old 1 Week Ago Thread Starter
davidpm's Avatar
Re: Oil Analysis
Winches and sails were fine. If I remember the draft was about 5' maybe a couple inches over.
The guy that bought it came from FL and shipped it back home.
I would have thought he could have found a boat closer but who knows.
davidpm is offline
post #10 of 20 Old 1 Week Ago Thread Starter
davidpm's Avatar
Re: Oil Analysis
You don't think the glycol was a problem?
davidpm is offline
Oil Analysis engineer_sailor Diesel 8 08-25-2015 07:44 PM
Ford Lehman Oil Analysis **Help! S/V Arabesque Diesel 5 02-03-2012 08:42 PM
Oil analysis suggests stuck rings. preservedkillick Diesel 11 11-14-2011 11:35 AM
Transmission oil analysis interpretation Petar Diesel 5 03-27-2010 10:25 PM
Oil sample analysis? 4748 Gear & Maintenance 4 12-14-2003 10:44 PM
