Westerbeke 4-108: How many hours are too many? - Page 2 - SailNet Community
post #11 of 15 Old 01-25-2007
pigslo's Avatar
I still think you just need to turn on the key or start the engine for 5 minutes and compare the meter to your watch. Cruising World Feb '07 has an article that mentions 8,000 to 9,000 hours as being the end of a diesel's reliable life.
pigslo
pigslo is offline
post #12 of 15 Old 01-25-2007 Thread Starter
Send a message via MSN to LWinters
I can rule out the possibility of running up the meter by having the key on since this old girl doesn't need a key to run. You are right Pigs. The meter is easy to check and something I'll do next time we are out. My primary concern is making sure the engine is sound regardless of the number of hours.
I've often heard that the 8-10K hour range is the retirement years for a lot of marine engines. I've also heard the flip side that when these diesels have been run in their power bands and kept dry with regular maintance they can push 15k hours.
Camaraderie, the list you provided is a good way ensure Iíve got the right spares and how to install them. This makes the most since to me. Iíll run through that drill along with an oil analysis and see where I sit. I know it is time to scrub the heat exchanger anyway. Might as well dig in while it is cold outside.
s/v Jargo
Singlehanding to Panama and beyond
LWinters is offline
post #13 of 15 Old 01-25-2007
pigslo's Avatar
I took my heat exchanger to a radiator shop and the soaked it overnight. No overheating since.
pigslo is offline
post #14 of 15 Old 01-25-2007
Ditto the check on heat exchanger/oil cooler on westerbeke. Be relentless about your pencil zincs.
sahara is offline
post #15 of 15 Old 01-28-2007
Valiente's Avatar
I have a Westerbeke W-52 in the same general design ballpark as the 4-108, but I have the opposite problem: too few hours. There's only 1,260 hrs on this 18-year-old engine, which is what happens when you build a motorsailer on the Great Lakes and then never leave the Great Lakes: 80 hours a season of use.
We intend to leave the Great Lakes on a circunavigation in '09. My mechanic is suggesting at the very least a top rebuild (visible condensation rust on the valve springs, rockers, etc.) and I will haul the engine for this next fall. I will also get the usual oil analysis, inspection/flushing of heat exchange, oil and transmission coolers and other bits and pieces. Add to that a full paint job, gasket change-out, belt(s) replacement, replacement of all original hoses (none are rotten, but all can be spares), and the change to a Balmar 100 amp alternator and I will be far more confident that this heavy chunk of change will be good for the 2,000-3,000 hours we could easily put on her in a five-year trip.
If the engine isn't worth rebuilding (and there is no real sign that it isn't), then I will go for something similarly powered as I am also getting a custom VariProp that will be made for the power bands this model achieves.
So my points are two: a) not enough engine hours are possibly even more destructive than too much, and b) as far as I can tell, a "prophylactic" rebuild with an eye to keeping the better cast-off parts as spares (depending on your carrying capacity) is an exceptionally good idea. Even a full rebuild that replaces the entire drive train in the block is going to be significantly cheaper than a new equivalent diesel, and you won't have the issues of redoing motor mounts, couplings, etc.
Not to mention that while the engine's out is a great time to clean up the whole area, replace the engine mounts, move to PSS-style stuffing box if you like and to pull the shaft for inspection for trueness and scoring. Also, you can refresh your exhaust hoses, waterlift, fuel filtering system, etc. If they are of the same vintage as the engine, they are probably due for replacement. Bad fuel and back-pressured water are the two worst diesel enemies in my admittedly limited experience.
It may not *seem* like an opportunity, but it will raise your confidence considerably while on passage.
Valiente is offline
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
The Art and Science of Standing Watch John Rousmaniere Seamanship Articles 0 02-08-2004 07:00 PM
The Art and Science of Standing Watch John Rousmaniere Cruising Articles 0 02-08-2004 07:00 PM
The Art and Science of Standing Watch John Rousmaniere Racing Articles 0 02-08-2004 07:00 PM
The Art and Science of Standing Watch John Rousmaniere Her Sailnet Articles 0 02-08-2004 07:00 PM
