High pressure zodiac - Page 2 - SailNet Community
post #11 of 13 Old 01-27-2007
I'm really not surprised, since if you're out cruising, the boat is your house, the dinghy is your car for all intents and purposes...
sailingdog is offline
post #12 of 13 Old 01-28-2007 Thread Starter
That's good to hear Camaraderie. That's sort of been the evolution of my thinking. I was originally looking at the smallest dinghy with the smallest engine that would allow it to plane with two people aboard. Now I'm leaning towards the biggest dinghy I can afford and an engine that will be somewhere in the upper end of what the boat is rated for. When I thought about exploring lagoons and perhaps coming across a time where I have to move fuel or water or even a large load of provisions by dinghy, it didn't make sense to mess around with a 4-6 hp engine on a 9 foot dinghy. Like you said, your dinghy is like your car. I'll get a dinghy longer than ten feet to make up for my subaru wagon and a 9.9hp yamaha to make up for the motorcycle. Hmmm, maybe I should make that a 25hp.....that's just silly. Thanks agian for the advice. I'll have to seriously consider the pros and cons of a RIB.
Newport41 is offline
post #13 of 13 Old 01-29-2007
Valiente's Avatar
Let me know what you decide. After nearly losing the Zodiac 310 RIB and the prop when a davit snapped in five feet of Lake Ontario "sea" this year, I am convinced that davits are a mixed blessing at best and a positive hazard in a seaway. Fine in harbour, but I am going around in my mind for my 41 foot steel cutter with the following options:
a) Retube the Zodiac in Hypalon. Positives: Proven, a great tender, rows semi-well, tows very well, carries half a ton, hard to sink, very stable. Negatives: Quite heavy even without oars, engine, tank, AGM for lights, assorted crap. Blocks a lot of foredeck. Dodgy to launch or retreive when wind or sea is up, esp. if engine (four-stroke 9.9HP) must be taken on and off. Cost of retubing equals or exceeds complete replacement with other options.
b) Hypalon inflatable. Positives. Stowable in forepeak. Considerably lighter. Negatives: Doesn't track as well, doesn't row well, less capacity, costly, long time to inflate/deflate/deploy
C) AquaPro aluminum hulled RIB at nine-foot-length. Positives. Decent compromise at lower weight (70 lbs). New costs less than retubing existing RIB. Can plane with a smaller engine, say a 6 or 8 HP 4 stroke, or even just use a 40 pound 4 HP for putting in and out. Negatives: Less capacity. Durability a question and rep of AquaPro not yet gauged.
d) Walker Bay 9-foot polypropylene tender with inflatable ring at "rim". Positives: Rugged, good rower, tows well, inflatable aspect lends considerable stability, light weight (80 lbs.), takes a max. 4 HP motor, can be rigged as sailboat with add-on kit. Negatives: Capacity is two adults, stretched to man, woman and child with small cargo. Takes less space than Zodiac on deck, but still a fair bit. Possibly short enough to stow athawartships.
e) Portabote, 10 or 12 foot. Positives: Rugged, relatively well-attested quality. Light, compact, stowable, rowable, towable. Can be made into a sailing dinghy. Cargo capacity pretty good. Negatives: Stability issues? Time needed to assemble and break down probably similar to inflatable.
We haven't even discussed that a major part of a cruising tender's life is taking out lines, second anchors, lines to shore and various dirty jobs like fuel in jerry cans, etc. I've even lashed my RIB to the mothership's side and solved a dead engine and no wind issue by motoring home with the outboard. No wonder my seams are failing...
That's what I've come up with. If I could stow the RIB on deck painlessly (or on the pilothouse, but I want solar panels up there.
I'll report here if I have blinding flashes of inspiration.
Valiente is offline
Breadmaker aboard CHRISTINE-R Provisioning 21 08-15-2006 12:43 AM
At sea. Volvo Ocean Race: Sanderson still leads but high pressure ridge good change everything @ BYM Sailing News NewsReader News Feeds 0 04-15-2006 09:16 AM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Avon high pressure floor mikemosabe Gear & Maintenance 5 08-17-2002 04:44 AM
Understanding High-Pressure Systems Michael Carr Seamanship Articles 0 04-06-2001 09:00 PM
