best way to remove rust? - Page 2 - SailNet Community
post #11 of 25 Old 01-28-2007
Most supermarts will stock "Kurly Kate" or similar scrubbing pads, copper, brass, or stainless scouring pads all more abrasive than the many plastics now sold. The only use for steel wool on a boat, is to plug mouse holes. Mice don't like to chew on it. If you've got no mice, you don't need Brillo.
hellosailor is offline
post #12 of 25 Old 01-28-2007
If you get stainless steel scouring pads...make sure they're non-magnetic stainless... or they're likely to cause rust spotting as well. I like the nylon ones, since they're less troublesome and just as effective, and less likely to do damage to the gelcoat if you're removing stains.
sailingdog is offline
post #13 of 25 Old 01-28-2007
SD-
3M's nylon scrunge pads are actually color coded according to how abrasive they are. I don't remember the code but offhand, IIRC the blue ones are for scrubbing and the pink/white ones are for use on non-stick coatings, probably safest for gelcoat. 3M's famous one-call-finds-out-everything 800# can get the facts on that one. (Other makers will follow their own codings.)
post #14 of 25 Old 12-02-2009
Doug Gierula
Starclean is my favourite for cleaning stainless. Comes in a tube like toothpaste, a little bit goes a long way.
Doug Gierula
Klacko Marine Inc.
905.945.2579
klacko is offline
post #15 of 25 Old 12-02-2009
1975 Newport 28
jaschrumpf's Avatar
Whither naval jelly? Is it only for breakfast now?
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #16 of 25 Old 12-02-2009
flitz metal polish, work great. you can even use it on plex, lexan and paint.
scottyt is offline
post #17 of 25 Old 12-02-2009
There is a product called "SpotlessStainless". Shake it up, paint it on, keep it moist, thirty minutes later wash it off. Melts rust away. Fantastic stuff.
ughmo2000 is offline
post #18 of 25 Old 12-02-2009
FSR...Fiberglass Stain Remover, available as a blue gel and in a spray bottle are true miracles waiting to happen. I wouldn't have the spray on my boat under any circumstances...it wicks into places you don't want it, and though it removes rust, that rust will reoccur with a vengance. The gell on the other hand, can be placed accurately with one of those aptly named acid brushes if you trim the bristles to about 1/4". I've removed rust stains on my mainsail with it with no ill effect. It can be (and should be) neutralized with a few squirts of Windex. Good stuff, actually.
Howard Keiper
Berkeley
thekeip is offline
post #19 of 25 Old 12-02-2009
jjablonowski's Avatar
Scotty's right. Flitz.
jjablonowski is offline
post #20 of 25 Old 12-05-2009
Shortman's Avatar
FSR works very well, which if I remember right is just oxalic acid
Shortman is offline
how to remove folding prop? mcagney Gear & Maintenance 1 07-20-2005 11:23 AM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 08:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 08:00 PM
