New to Dyneema, want to make lifelines - SailNet Community
 6Likes
post #1 of 17 Old 1 Week Ago Thread Starter
Minnesail's Avatar
So I'm adding stern rails on my little boat and will be re-doing the lifelines.
I think I'd like to do the lifelines in dyneema. It looks like it should be fairly simple. For the gate end get a pelican hook that has an eye instead of a wire swage. For the other end just tie it to the pulpit with lashings.
Per side/gate I'd need a pelican hook, a length of lifeline dyneema, and a short length of smaller dyneema for the lashing. Does that sound right?
What sort of dyneema is good for lifelines, and how do you splice it?
What should I order for the smaller dyneema?
I've never worked with dyneema before and I'm pretty new to splicing. I do have a fid, but it may be too big for dyneema.
Thanks in advance!
Catalina 22
on a starboard tack
Minnesail is offline
post #2 of 17 Old 1 Week Ago
Re: New to Dyneema, want to make lifelines
See: http://www.ussailing.org/wp-content/...May%202013.pdf
Minnesail likes this.
Plumbean is offline
post #3 of 17 Old 1 Week Ago Thread Starter
Minnesail's Avatar
Originally Posted by Plumbean View Post
Awesome, thanks!
I'm thinking about going with Samson's Control DPX. I use it for my halyards so I'm familiar with it. It's pretty easy on the hands and you can tie regular knots in it. 1/4" line has 3800 lbs breaking strength, so even if I cut that in half by tying a knot it would still be stronger than my stanchions.
Catalina 22
on a starboard tack
post #4 of 17 Old 1 Week Ago
Most all the ropes have enough strength.
UV and chafe resistance are my biggies.
I think it's also good when you can cut a lifeline/any line with a pocket knife.
Somebody could market thin, zero-chafe stanchion inserts....
oysterman23 and Minnesail like this.
RegisteredUser is online now
post #5 of 17 Old 1 Week Ago
Kynntana (Freedom 38)
gamayun's Avatar
I used tubing that fit over the Dyneema and inside the stanchion tubes to reduce chafe. Seems to work pretty well but it's super snug. You can make the tubing a little more malleable by heating it up a bit in hot water. I don't think that affects the Dyneema strength, but you should check. I also used the modified Brummel splice videos from Colligo Marine (Tech. Videos ? Colligo Marine®).
gamayun is online now
post #6 of 17 Old 1 Week Ago
Originally Posted by gamayun View Post
....modified Brummel splice videos from Colligo Marine (Tech. Videos ? Colligo Marine®).
That's a good video - better than others I've seen.
Single braid is a piece of cake, imo.
Thanks.
post #7 of 17 Old 1 Week Ago
JimsCAL's Avatar
Originally Posted by Minnesail View Post
Awesome, thanks!
Note that Control DPX is a blend with polyester and has about 1/3 the strength of 100% dyneema line of the same diameter. I would use the real stuff and go with a simple bury splice rather than knots.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #8 of 17 Old 1 Week Ago
I made dyneema lifelines for a friends J-29 last year and spliced (simple, easy even for me) one end and lashed the other so he could go end for end when started to chafe at stanchions.
I used 5/32" dyneema rated @ approx. 4,000 lbs.
Wanted to coat with Yale Maxi jacket coating for chafe protection thru stanchions but were installed before I could coat.
HUGOSALT is offline
post #9 of 17 Old 1 Week Ago
gamayun's Avatar
Thanks.
You're welcome! I could not figure out the written instructions, but these videos (where I could stop at each step) were perfect. They generally took me about 15 min to do, though with practice, it would easily be faster than that.
post #10 of 17 Old 1 Week Ago
This is what I did. Simple bury splice on both ends (one with a pelican hook and the other with thimble), lock stitched. Using the plain dyneema I upsized to 6 mm so stronger than the stainless steel it replaced. I used the stuff from CS Johnson for the pelican hook. My stanchions were new and smooth, so not concerned about chafe protection.
Plumbean is offline
dyneema eye splice for lifelines hivoltage Gear & Maintenance 18 09-27-2015 12:14 PM
Lashing for Dyneema lifelines? Irunbird Gear & Maintenance 8 07-24-2012 12:20 PM
Going to redo lifelines in Dyneema...what size? NewportNewbie General Discussion (sailing related) 5 04-28-2012 08:43 PM
Dyneema lifelines AdamLein Gear & Maintenance 45 04-16-2012 10:00 PM
Dyneema Lifelines Installed Squidd Gear & Maintenance 9 03-24-2012 11:59 PM
