Thru Hull Sealant Question - SailNet Community
 1Likes
  • 1 Post By TQA
post #1 of 7 Old 1 Week Ago Thread Starter
I'm taking the advice from sailnet members and pulling my boat to re seal the speed and depth transducer.
The sealant should be: for below water use, not permanent (5200), fast curing. I plan to use a non wood spacer.
I need to reuse the fittings so I plan to "Jack" out the thru hull fittings as suggested by Nigel Calder.
Suggestions are always welcome.
Thanks
Capt Mulch is offline
post #2 of 7 Old 1 Week Ago
Re: Thru Hull Sealant Question
Sikaflex 291.
Keth
Boat Vinyl Lettering and Graphics
Bleemus is online now
The Following User Says Thank You to Bleemus For This Useful Post:
Capt Mulch (1 Week Ago)
post #3 of 7 Old 1 Week Ago
TQA
Bombay Explorer 44
TQA's Avatar
I used 3M 4200 on mine 7 years ago so far so good.
seabeau likes this.
TQA is online now
The Following User Says Thank You to TQA For This Useful Post:
post #4 of 7 Old 1 Week Ago
Cruiser
wrwakefield's Avatar
We just finished our haul-out and installed one new through-hull using 3M UV4000.
I keep it on-board because it can be use above and below the waterline, and because I have successfully had an open tube stay viable for over 3 years by storing it in the freezer. [Thaw and bring to room temp before use...]
This stuff costs us over US$30/tube up here so long term storage of partially used tubes is important...
I have also had great success with 3M 4200, but haven't had occasion to keep an open tube in the freezer to determine if it stays viable... [It likely will...]
In case this is helpful.
Cheers! Bill
wrwakefield is offline
The Following User Says Thank You to wrwakefield For This Useful Post:
post #5 of 7 Old 1 Week Ago
I would check the manufacturer's thru hull installation instructions (if you can find them). Some manufacturer's say not to use certain sealants because they cause cracking of the plastic thru - hulls.
For example polysulphides should not be used with ABS or Lexan. Polyurethane based sealants should not be used on most plastics--acrylic, polycarbonate, PVC, or ABS. Marine Silicone is usually safe with plastics (not the household kind that smells of vinegar)
It's important to get this right! Of course if thru-hulls are metal, no problem using sealants below.
Boatlifecaulk - polysuphide
Sikaflex 291 - Polyurethane
3M 4000/4200/5200 are polyurethane based.
FreeAgent is online now
The Following User Says Thank You to FreeAgent For This Useful Post:
post #6 of 7 Old 1 Week Ago
BoatLife 'LifeSeal" is my first choice for 20 years. Safe with plastics, too.
olson34 is offline
The Following User Says Thank You to olson34 For This Useful Post:
post #7 of 7 Old 1 Week Ago
chef2sail's Avatar
Cheers! Bill
Good tip....thanks
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Sealant compatability with Coelan deck sealant Rockter General Discussion (sailing related) 0 09-12-2016 06:04 PM
Deck - Hull Sealant.... regatta Gear & Maintenance 5 03-20-2012 10:19 AM
Another sealant question brak Gear & Maintenance 7 05-17-2008 08:58 PM
Thru Hull Sealant dbruce85 Gear & Maintenance 17 04-16-2008 10:22 PM
Hull Question artbyjody Sailboat Design and Construction 17 02-19-2008 01:22 PM
