-   -   Tachometer (http://www.sailnet.com/forums/gear-maintenance/28535-tachometer.html)
morganbill 01-30-2007 11:12 PM
Tachometer
When I turn the ignition key to on, the tachometer will cycle from 0 to max rpm and back about 10 times a minute whether the engine is running or not. Also the oil pressure gage is pegged high. Just wondering if this is as simple as a missing wire. The tach is run off the alternator and the engine is a Volvo-Penta diesel with a Volvo-Penta insturment panel.
Thanks for any insight.
Morgan Bill
Valiente 01-31-2007 11:07 AM
Morgan Bill
That could be a number of things, (intermittant short comes to mind) but if it's any guidance, when I turn on the blower on my glass fuse-protected Atomic 4 (when its running), the oil pressure meter drops 30 psi, the temp gauge goes up 10 degrees and then both snap back when I push the blower switch in.
I've learned not to freak out, rather than to actually trace the issue and fix it.
resdog 02-02-2007 01:57 PM
A poor ground will cause an electric tach to jump around.
