-   -   Orca Green LED Masthead Light (http://www.sailnet.com/forums/gear-maintenance/28541-orca-green-led-masthead-light.html)
capecodphyllis 01-31-2007 01:12 AM
Has anyone used/installed Orca Green's Argo Navis LX Series TriAnchor Light (Masthead LED TriColor Navigation and Anchor Light with strobe and daylight sensor)? The lights are "2 mile visiblity" and USCG approved.
Here are the details. Not sure how durable it is, or if it has silver-plated connectors. I notice the light does not use a "fresnel lens".
It has a 0.5 Amp power draw at 12 VDC (either mode).
http://www.sailorssolutions.com/inde...&Item=LEDNAV04
sailingdog 01-31-2007 10:21 AM
I have the same light. It is excellent and fairly durable. I does not use a fresnel lens, as the diodes have a lens built into them. I don't remember if the wires were tinned, but believe they were. I've been using it for about a year.
capecodphyllis 01-31-2007 06:55 PM
If I understand correctly you have three switching options:
1. Tri-Color Navigation Light
2. 360 Degree White Anchor Light
3. 360 Degree Anchor Light Flashing On/Off
How bright and diffuse is the light when compared with standard bulb lighting?
I guess bright enough, or you wouldn't be happy about spending $400 on it.
http://www.sailorssolutions.com/Prod...LEDNAV04_1.jpg
I'm trying to decide between this unit and the Lopolight unit.
http://www.lopolight.com/products/pr...x?item=200-005
http://www.lopolight.com/products/im...ze/200-005.jpg
Thanks for the info.
sailingdog 01-31-2007 07:15 PM
It's actually brighter than the anchor light I had on there, and uses far less electricity. I had looked at the lopolight unit, but it wasn't as versatile from what I could see. Also, availbility on the Lopolight unit was significantly worse at the time, but this may have changed.
catamount 01-31-2007 09:20 PM
The LopoLight you linked to does not have the anchor light option, whereas the OGM does. I didn't dig far enough to find out whether Lopo offers an anchor light or not. My recollection from a year ago is that the Lopo unit was more expensive (about double the price) than the OGM light, but that may have changed. I have the OGM tri-color with anchor light and photodiode, but not the strobe option. It has been excellent so far, and I am very happy with it.
sailingdog 02-01-2007 01:49 AM
I believe catamount is correct on lopolight not having a tri/anchor combo.
capecodphyllis 02-01-2007 07:52 PM
Lopolight has a tricolor/anchor model, but not a tri-color/strobe model.
(See image below and link for details)
Problem is, the Lopolight 2nm tri-color/anchor light for boats over 40' has a suggested retail of $685.00 - ouch! The Lopolight 3nm steaming light has a suggested retail of $860.00 - yeeeouch!
They're both about the size of a hockey puck.
http://www.lopolight.com/products/pr...x?item=200-007
http://www.lopolight.com/products/im...-007%20mid.jpg
http://www.lopolight.com/products/im...-011%20mid.jpg
sailingdog 02-02-2007 12:31 AM
I doubt that the lopolight is as efficient as the OGM trianchor, since the lopolight design uses a lot more LEDs.. Probably draws a fair bit more power for that reason too.
