Old 02-03-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Wishful thinking?
I found myself wondering this morning if it wouldn't be possible to have a software program for battery monitoring. Where instead of running the wires from the shunt to what in essence is a mini-computer, run them to the laptop instead. Or does something like that already exist? Or, is it even possible?
What say ye?
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 02-03-2007
A dedicated battery monitor would probably be easier to install, more durable and last longer, and probably cheaper in the long run. It would also use considerably less energy than having to have a laptop up and running... so the batteries would be more useful...
A laptop has to power a large LCD panel, which is really not necessary for the purposes of monitoring battery status; it has to power a hard drive, which is also not necessary for monitoring battery status; it has a cpu that is far in excess of the power needed to run the simple software necessary for battery monitoring and as such will use far more power than a dedicated device; the laptop becomes a point of failure for multiple systems—not only do you lose your laptop, word processor, e-mail, etc, but also your battery monitoring capabilty if anything should happen to the laptop.
Furthermore, most laptops are not hardened for a marine environment and are subject to failure from exposure to water, salt air, etc. A dedicated device could easily be made water-resistant or waterproof, as well as sealed against the corrosive effects of the salt air via a conformal coating of the electronics or sealing the electronics within an epoxy block. A dedicated device could be made much smaller, simpler and use far less power.
Finally, such a device already exists... see here, here or here for a few examples.
Old 02-03-2007
PBzeer's Avatar
Wandering Aimlessly
I already use a laptop for charting, so it isn't as though I would be using one, just for a monitor. But mostly, it's just wishful thinking.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 02-03-2007
Well, the other thing I'd point out is that you'd have to turn on the laptop, if it was off, wait for the OS to boot, and then run the program to check the status of the batteries, if the laptop were off... having a dedicated device means that you can see the status of the batteries almost instantly, whenever you want....
Old 02-03-2007
Pamlicotraveler's Avatar
Pamlicotraveler is on a distinguished road
PBeezer- are you trying to complicate your life? I thought you were going to start simplifying it. If your blog turns into a discussion of software battery monitoring I am going to stop reading it!
The next best thing
To playing and winning is playing and losing.
Robert Lee Castleman
Old 02-04-2007
PB I think keeping it simple is the solution...as they said above.
here's simple...I have 4 batteries and 4 independednt battery monitors with high, low and low-low audible and visual alarms ....1 Volt meter 1 amp meter both with 4 position switches....the monitors can be adjusted to different voltages, for example the engine battery alarms low bat at a higher voltage than the house or the VHF battery.
My Garmin GPS also has battery monitor feature, and I can program it to alarm at given battery levels.
What do you do when the PC is off or decides it needs to reboot??
Here's part of the bat monitor system (here for 2 batteries only).
Old 02-04-2007
PBzeer's Avatar
Wandering Aimlessly
Please reference the title of the post. Just some pipedreaming. (And no, not that kind of pipe!) I'm using a Link 20 and have 2 multimeters for backup.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 02-04-2007
camaraderie's Avatar
moderate?
Old 02-04-2007
marinesniper is on a distinguished road
PBZeer:
I am with you from a tech/geek aspect, I think it would be cool to monitor the battery the engine or anything I could off my laptop...would I use it instead of the more conventional monitors and marine gear on a long cruise...no...but it is fun to mess around and play with these things when bored...!
1981 - 30' Lippincott cruise/racer Miami, FL
One shot one kill !
Old 02-04-2007
PBzeer's Avatar
Wandering Aimlessly
marinesniper - that's kind of what I had in mind, a way to analyze systems in one program. Something like what they do with cars now.
John
Ontario 32 - Aria
JCP
- Website & Blog
Thinking of buying wbk728 Boat Review and Purchase Forum 5 09-26-2011 04:48 PM
Anyone From Pacific Northwest Thinking Of Circumnavigating??? shabbychic Cruising & Liveaboard Forum 2 01-04-2007 06:58 PM
Rookies who are thinking about competing in the 52nd West Marine Columbus... (Miami Herald) NewsReader News Feeds 0 09-28-2006 03:15 AM
Deep Thinking in the Bahamas Michelle Potter Cruising Articles 0 03-04-2004 07:00 PM
Thinking and Looking Ahead Carol Cronin Racing Articles 0 02-13-2002 07:00 PM
