02-04-2007
The super-expensive battens from West Marine are less likely to break and then tear your sails than pine trim boards from Home Depot would be. Perhaps oak or ash would work, but they can be difficult to find. (Have you tried Sail-Net for batten prices?) Broken battens are no fun. Where are you going to get a new sail? Perhaps the sailmaker has battens at a better price, or you can arrange for the new sail to have battens the same lengths as the old one. Be wary of cutting open the batten pockets. Sailmakers have many ways to get battens to go in and stay in their pockets. A pocket that looks like it's sewn shut may have a slit entry further down the pocket, or be open at one end on the top, or open at the other end for some reason. Ours have velcroed flaps that hold the battens in, and need a "pusher" to load them. Tape will not be enough to hold the battens in if the pocket isn't spring-loaded (as many are). Sewing isn't difficult, and if the sails are in as poor shape as you seem to say, learning on them won't affect them much. You DO need to use sail needles and a sailor's palm to push (and perhaps vicegrip pliers to pull) the needle through the sailcloth, however. Regular needles will break when you try to push them through such tightly woven material.
