02-04-2007
overheating kubota
oops.....sorry in advance for the double post
hi, any thoughts on this one? i have a kubota 22hp, which had been operating flawlessly for the last 6mths. suddenly its started the following traits- it will run great for about an hour at 2500rpm, engine pressure ok, temp ok, water out the exhaust ok, then for some reason, oil pressure drops, temp goes up, and the engine overheating alarm goes off. i shut the engine off for about 15minutes, then everything is fine again until the next occurence. any suggestions?
btw how do i put that radiator anti corrosion stuff in my engine? do i just add it directly to the radiator w/ some water?
sorry for asking what may be a dumb question. thank you
