Lightning protection on 1991 Hunter 30 - Page 2 - SailNet Community
post #11 of 12 Old 02-05-2007
There is no reason you can't use an unencapsulated metal keel for a ground in a lightning protection system. If the keel is encapsulated, then you will have a problem if you do so...but with an unencapsulated keel, it should be fine.
I'd second reading the website that CruisingDad pointed out... it is very comprehensive and detailed.
Brezzin-
If the compression post was stainless steel, then your grounding system was probably inadequate as a lightning protection system. Stainless steel has a fairly high electrical resistance, which is also why you shouldn't use stainless steel washers in your electrical setup.
sailingdog is offline
post #12 of 12 Old 02-05-2007
Brezzin's Avatar
No, the post was not Stainless. Having never been hit by lightning in 18 yrs of ownership of that boat, I really don't know if that grounding did any good.
I was just responding to a more general Hunter side of the question. I myself believe that a more comprehensive method be used to ground the boat than just the compression post to keel cable.
Brezzin is offline
Lightning Strike! Kathy Barron Seamanship Articles 0 04-07-2005 09:00 PM
Lightning Strike! Kathy Barron Gear and Maintenance Articles 0 04-07-2005 09:00 PM
Lightning Strike! Kathy Barron Cruising Articles 0 04-07-2005 09:00 PM
Lightning Examined Kevin Hughes Seamanship Articles 0 05-10-2004 09:00 PM
The Path to Lightning Protection Kathy Barron Seamanship Articles 0 08-13-2003 09:00 PM
